2000 Volvo S70
15 replies to this topic
#1 josehb
josehb
  • 5 posts
Posted 10 March 2005 - 06:08 PM
I have a 2000 Volvo S70 with 60,000 miles. I checked the ATF and it looked very brown, so I would like to change it. My question is, is it OK to use the new Mobil ATF 3309 fluid which meets the volvo fluid JWS3309 specs. for this Aisin AW transmission.
The volvo dealer sells this ATF which is synthetic for $18.00/QT and I found the Mobil ATF 3309 for $4.50/Qt, big different !!
The only different is that the Mobil ATF 3309 is not synthetic, would this matter given that the specs are the same?
I would really appriciate an experts oppinion, since the diferennce in price is very significant.
Jose
#2 Gregg
Gregg
    daniel stern lighting pimp
  • 2,611 posts
Posted 10 March 2005 - 06:21 PM
from your owner's manual:
Automatic transmission fluid
Quality:
AW4: ATF Dexron III and Mercon.
Capacity: 8 US qts. (7.6 liters)
AW5: Only Volvo gearbox oil (1161540-8). Do not mix with other oils.
Capacity: 8 US qts. (7.5 liters
As long as it meets the proper specs, it should be fine.
Edited by gmischenko, 10 March 2005 - 06:22 PM.
#3 josehb
josehb
  • 5 posts
Posted 10 March 2005 - 06:33 PM
Thanks, from what I understand as long as it meets the specs it should be Ok and the only diference between synthetic and non synthetic is durability: but I'm not sure.
#4 Gregg
Gregg
  • 2,611 posts
Posted 10 March 2005 - 06:41 PM
My suggestion is if you are unsure, just go with the Volvo ATF. You don't want to fubar the transmission by using the wrong fluid. Sure, it seems like a lot more money now, but it is nothing compared to the cost of a new transmission.
#5 josehb
josehb
  • 5 posts
Posted 10 March 2005 - 07:44 PM
I just called Mobil at 1-800-662-4525, which is there lubricant division in Virginia. They claimed that it meets the volvo specs. and it does not matter if is synthetic or not. So I'm going to go and use the Mobil ATF 3309 fluid.
#6 Joe_m
Joe_m
  • 83 posts
Posted 10 March 2005 - 09:29 PM
QUOTE(josehb @ Mar 10 2005, 02:08 PM)
Jose
Is yours a NA with the 5 spd auto? Just trying to compare yours to mine...
former owner of a 2000 S70 NA
How could you guys let me sell it?!
#7 Guest_Guest_*
Guest_Guest_*
Posted 11 March 2005 - 05:25 PM
The transmision is the AW5 5 speed automatic, made in Japan by the Aisin Wagner Company and from what I undestand they make among the best transmissions on the Planet.
However, this transmission requires a special ATF meeting the JWS 3309 specs.
#8 MrWinkey
MrWinkey
    Am I drunk? You tell me!
  • 4,759 posts
Posted 12 March 2005 - 12:16 AM
It's your car my friend ..but I would use full syn. your crazy if you don't ? Now that's just my opinion....someday I hope to get out of McDonalds and become a Volvo technician cool.gif
"SMOKE TROUT NOT CRACK"
#9 Bay13
Bay13
  • 6,378 posts
Posted 12 March 2005 - 04:48 AM
I think he means it doesn't matter if his transmission is using synthetic or dexron, the mobil 1 synthetic will cover the bases.
#10 spottieottie
spottieottie
  • 860 posts
Posted 12 March 2005 - 05:00 AM
'96 850 Turbo Black 'n Tan---------------FOR SALE!!!!!!!!!!!!
'98 S70 T5M black/ black ----- PARTING OUT let me know what you need.
2000 Suzuki DRZ400E desert pony
2006 Suzuki SV650S power wheelies are FUNN!!!
#11 KLS
KLS
  • 727 posts
Posted 13 March 2005 - 10:28 PM
Mobil 3309 is not a Dexron-III ATF and not suitable where a Dexron-III ATF is called for. It is rated to replace the special Volvo JWS3309 ATF.
Mobil 1 ATF is a Dexron-III ATF, but not suitable for the Volvo transmissions that require the special Volvo fluid.
I prefer a synthetic ATF for longer fluid life and higher film strength (if it is a PAO base fluid). Redline D4 ATF is my choice if the Volvo JWS3309 fluid is required. If Dexron-III ATF is required, I like the Redline, Mobil 1, Amsoil, or Schaeffer.
Dexron-III, Mercon, JWS3309, and other ATF specs are performance specs, especially relating to the friction characteristics. The friction modifier properties must meet the properties of the clutch materials.
Synthetic or conventional ATF relates to the ingredients used to make the ATF, not the friction performance.
Ken
#12 Bay13
Bay13
  • 6,378 posts
Posted 13 March 2005 - 10:37 PM
QUOTE
Thank You
#13 Guest_Guest_keefus_*_*
Posted 14 March 2005 - 06:37 PM
Anyone know where to get the Mobil 3309 in Virginia????? Otherwise, I will be using Redline D4, since that will also work in my VW Passat.....
keefus
Richmond, VA
#14 josehb
josehb
  • 5 posts
Posted 17 March 2005 - 06:53 PM
Thank You, Ken for that explenation, I will also consider the Redline d4.
#15 josehb
josehb
  • 5 posts
Posted 17 March 2005 - 07:04 PM
Well, I just checked the specs for Redline D4 it it looks like it does not meet the Volvo JWS3309 specs. I wil still stick to the Mobil 3309, if it ruins my transmission I should be able to sue them, since they claime it meets the Volvo fluid rigth on the bottle.
#16 Joe_m
Joe_m
  • 83 posts
Posted 21 March 2005 - 02:14 PM
QUOTE(Guest @ Mar 11 2005, 01:25 PM)
Where did you find the reference to the JWS 3309 specs? I am trying to verify and see nothing of it in the manual.
