O2 Sensor Connector! Im Losing My Mind!
#1 Graham McMicken
  • 9 posts
Posted 16 March 2005 - 07:11 PM
Hey all,
Just bought a new bosch pre-cat sensor. For the life of me, I cannot get the male-female connector apart!! I got it of the metal clip, but theres absolutely no room down there to work with!
It looks like the red part slides out, freeing the pegs. Is this correct? is there a release area, Ive tried everything but I can only use one hand at a time, and barely see what im doing! Why does it have to be so darn strong!?
I cant go on like this anymore! The simplest part of the job has turned into hours of frustration.
- Graham
#2 MrWinkey
    Am I drunk? You tell me!
  • 4,759 posts
Posted 16 March 2005 - 11:57 PM
Slide a very small flat blade screwdriver under the red part and it pops up then you pull the male end out while pulling upward on the red part
"SMOKE TROUT NOT CRACK"
#3 Guest_Guest_Graham McMicken_*_*
Posted 17 March 2005 - 04:22 AM
Thanks, It was on there too tight, and because of the turbo it was impossible to get enough room to work.
I ended up just splicing it.
-G
IPD
