Resistance Of Plug Wires
9 replies to this topic
#1 Bay13
Bay13
  • 6,378 posts
Posted 18 March 2005 - 12:47 PM
Well this morning I measured a brand new set of OEM plug wires.
1 is 25" long and reads 4.68K ohms
2 is 22" long and reads 4.17K ohms
3 is 19" long and reads 3.428K ohms
4 is 15" long and reads 3.05K ohms
5 is 12" long and reads 2.4K ohms
The coil wire is about 12" and read 2.454K ohms
#2 gdizzle
  • 19,804 posts
Posted 18 March 2005 - 02:26 PM
QUOTE(Bay13 Admin @ Mar 18 2005, 06:47 AM)
Well this morning I measured a set of OEM plug wires.
Nice rich, I wonder what the resistance is on a set of magnacores etc.. When I upgrade the T5 I'll take some measurements.
Edited by gdogg16, 18 March 2005 - 02:27 PM.
#3 kenhoeve
kenhoeve
  • 2,617 posts
Posted 18 March 2005 - 04:41 PM
varies from .18 to .20 ohms/inch in your wires.
never thought about that, but it means the #5 gets double the voltage of the #1 cylinder. that really can't be ideal one would think.
2007 V70R
#4 lext
lext
  • 20 posts
Posted 18 March 2005 - 05:13 PM
QUOTE(kenhoeve @ Mar 18 2005, 09:41 AM)
Not necessarily.
If it's a closed circuit then that would mean the current going through wire#5 will be double the current through wire#1. But in terms of voltage loss, I think the difference will be small between voltage at spark#5 and spark#1, since the source voltage is so high and the wire resistance (i.e. voltage loss) is, relatively, so small.
'94 854 N/A. Everything has 'Volvo' on it.
#5 kenhoeve
kenhoeve
  • 2,617 posts
Posted 18 March 2005 - 05:28 PM
but we have a distributor. that means each wire gets the same current. and if V still equals IR, last i checked it did, that means half the voltage. granted it's a ton of volts, but still half in #1.
2007 V70R
#6 James A Sousa
James A Sousa
  • 307 posts
Posted 19 March 2005 - 03:47 AM
I think that a circuit with a surge of voltage and current and a gap in it will behave differently than a conventional closed circuit with several resistances.
For example, voltage drops across several resistances in a closed circuit will add up to the total voltage applied. In that case, the different wire resistances would cause different voltages to remnain to ignite the fuel.
However, a spark plug gap represents a very great resistance when compared to several Kohms, and the resistance in the wires may be relatively insignificant when compared to this gap.
The secondary ignition circuit is quite different than a closed circuit, as the current only flows when the spark plug gap is overcome by the voltage applied.
Measuring wires intended to carry large currents with an ohmmeter is not a complete test of suitability. I can subject a small resistor of the same resistance as your plug wires to the output of your ignition system and blow it to smitherines. Losing current and voltage to ground is an issue also.
Plug wires with the proper resistance may not be faulty, but this test is insufficient to prove that the wires are good.
If this opinion is faulty, it is because it is only meant to be food for thought. I may pipe in later if my thinking makes more sense to me!
Edited by James A Sousa, 19 March 2005 - 04:00 AM.
#7 Graham McMicken
Graham McMicken
  • 9 posts
Posted 19 March 2005 - 07:16 AM
QUOTE(James A Sousa @ Mar 18 2005, 08:47 PM)
I think your right, and the ohm test is conducted for 2 reasons.
1) The resistance is sufficient enough to suppress radio interference.
2) To check for abnormaly high resitance, which will most likely indicate an aged/defective wire.
I think that if the wire is out of spec. it is 90%+ likely to be bad. If the wire is in spec though, I dont think this necessarily means the wire is still good, as you mentioned before. Using an Ohm meter isnt meant to be a perfect determining factor, but it does help.
We would need something like... an ignition coil to test it thoroughly tongue.gif
- G
#8 Kashif
Kashif
  • 1,846 posts
Posted 19 March 2005 - 09:23 PM
Can this Data be added to the repairs section of the Website for future reference? It is always nice to know these kinds of things when one contemplates replacing their Spark plug wires.
#9 Kashif
Kashif
  • 1,846 posts
Posted 19 March 2005 - 09:33 PM
I am sort of a math guy rolleyes.gif,
so here it is in Ohms per foot
1 is 2.25k Ohms/foot
2 is 2.27k Ohms/foot
3 is 2.17k Ohms/foot
4 is 2.44k Ohms/foot
5 is 2.40k Ohms/foot
and Ohms per inch
1 is 0.1872k Ohms/inch
2 is 0.1900k Ohms/inch
3 is 0.1804k Ohms/inch
4 is 0.2033k Ohms/inch
5 is 0.2000k Ohms/inch
#10 Tom
Tom
  • 185 posts
Posted 21 March 2005 - 12:06 AM
The primary failure mode of ignition wires is not related to resistance from one end to the other. It is related to resistance between the core of the wire and the outside surface, which ideally should be infinite all along the wire - that's the insulation. If the insulation fails at any point, then when it rains the current travels to the outside of the wire and grounds through the moisture on the outside surface, bypassing the spark plug. Testing the wire resistance completely misses that problem - it only finds a problem in the relatively rare event that one wire becomes an open or near-open circuit.
Tom
'94 850 wagon, N/A, automatic, 170K.
