Best Way To Remove Slip-fit Exhaust Pipes?
9 replies to this topic
#1 lax01
lax01
  • PipPipPipPip
  • 4,781 posts
Posted 22 March 2005 - 06:17 AM
I want to remove an exhaust pipe from a slip-fit piece but I can't seem to even budge it, what should I do? Should I get a blow-torch and heat it up? I tried PB Blaster but that didn't work...any ideas?
2002 BMW M3
Past: 1995 Volvo 850 Turbo
#2 Volvoson
Volvoson
    Baby On Board Racing
  • 17,264 posts
Posted 22 March 2005 - 08:34 AM
QUOTE(lax01 @ Mar 21 2005, 10:17 PM)
We are talking pieces that have the U-Shaped clamps that hold them together?
If so, check to see if the pipes were bent due to the clamp being too tight. That happened when I was putting on my exhaust tip, and now I can't get that piece of pipe off. I tried using a chisel on it, but still nothing... I just put my tip on and said f*** it.
If the pieces are clamped together, I don't know of any alternatives other then cutting it... Heating it wouldn't help too much, unless it was just barely clamped together. Try it and see what happens.
Good luck
View Postgdizzle, on 21 May 2012 - 03:52 AM, said:
All the clean cars are in the PNW.
#3 orange850t
orange850t
  • 868 posts
Posted 22 March 2005 - 12:47 PM
SAWZALL........ sorry
95 855T Autumn Gold
#4 merlin390
merlin390
  • 2,778 posts
Posted 22 March 2005 - 01:01 PM
impact hammer with cutting head
#5 lax01
lax01
  • PipPipPipPip
  • 4,781 posts
Posted 22 March 2005 - 05:57 PM
greatttttttttttttttttttt thanks guys
2002 BMW M3
#6 chris_redxc70
chris_redxc70
  • 142 posts
Posted 22 March 2005 - 06:30 PM
pull really hard, if it is slip fit then it should come right off with enough pulling power, just besure not to rip your exhaust off
2000 Volvo XC70 - Venetian Red
IPD Black Mesh Grill
Alpine CDA-9831 H/U
Xenon Bulbs
17" MB Motoring Rev wrapped in Yokohama AVS ES 100
Carbon Fiber Cone Filter
De-Badged
15% Charcoal Tint back 5 windows
Eyelids - color coded
Speedtuning ECU (soon)
http://www.cardomain.com/memberpage/810229
#7 DEWFPO
DEWFPO
  • 539 posts
Posted 22 March 2005 - 07:10 PM
Gibbs, PD blaster, etc..., then heat it, then very large channel locks and twist it back and forth to break the rust/seal as you pull it off at the same time.
DEWFPO
#8 lax01
lax01
  • PipPipPipPip
  • 4,781 posts
Posted 23 March 2005 - 12:26 AM
took it to exxon, paid $40 and 2 minutes later, they had it off....much better than wasting my entire day, under the car, getting dirty and then having to goto Exxon because I couldn't get it off...lol wink.gif
testpipe is getting re-made and cat is getting fitted with slip-fit pieces...almost done
2002 BMW M3
#9 ziddey
ziddey
  • 1,005 posts
Posted 23 March 2005 - 12:34 AM
QUOTE(lax01 @ Mar 22 2005, 08:26 PM)
howd they do it
94 855t
#10 lax01
lax01
  • PipPipPipPip
  • 4,781 posts
Posted 23 March 2005 - 12:38 AM
heated it up with a cutting torch, got leverage on the pipe since they were underneath it and had two people pull on it....and used some type of wrench to grip it...
2002 BMW M3
