Trouble Code P0455
48 replies to this topic
#21 Nebor
Nebor
    TEAM BRAKE LUNCH
  • 3,472 posts
Posted 07 April 2005 - 11:04 PM
Yeah, the one that I removed had the connections at 90 degree angles. But this one fit right in, connector connected. I can only assume it works.
#22 Bay13
Bay13
  • 6,378 posts
Posted 07 April 2005 - 11:09 PM
It's not the one for your car, so I don't know how long it will work or if it will work correctly. But it might don't know.
#23 Nebor
Nebor
    TEAM BRAKE LUNCH
  • 3,472 posts
Posted 08 April 2005 - 04:27 AM
QUOTE(Bay13 Admin @ Apr 7 2005, 06:09 PM)
It's the one that FCPGroton sells tagged as "S70s 1998 Only."
It is radically different from the one I removed though. The old one didn't hold a vacuum going to the intake manifold.
#24 Nebor
Nebor
    TEAM BRAKE LUNCH
  • 3,472 posts
Posted 09 April 2005 - 06:30 AM
#25 MrWinkey
MrWinkey
    Am I drunk? You tell me!
  • 4,774 posts
Posted 09 April 2005 - 01:26 PM
QUOTE(Nebor @ Apr 9 2005, 02:30 AM)
Did you replace the gas cap with a factory one like was originally suggested or are you still using the pep boys cap?
"SMOKE TROUT NOT CRACK"
#26 Nebor
Nebor
    TEAM BRAKE LUNCH
  • 3,472 posts
Posted 09 April 2005 - 05:50 PM
QUOTE(MrWinkey @ Apr 9 2005, 08:26 AM)
Still using the generic gas cap, but I had it checked at an emissions station and it held vacuum just fine.... Should I still get an OEM cap? I don't know where my old one went...
#27 WhiteT5
WhiteT5
    Sampson
  • PipPipPipPip
  • 4,828 posts
Posted 09 April 2005 - 06:14 PM
QUOTE(Nebor @ Apr 9 2005, 11:50 AM)
IIRC, there is someone that sells the OEM Volvo caps on eBay for like $15 or so. I think that could be part of the problem. If not, the only other thing would be a leaky or disconnected hose that actually goes into the canister or the valve.
- Sean
#28 Nebor
Nebor
    TEAM BRAKE LUNCH
  • 3,472 posts
Posted 09 April 2005 - 06:36 PM
QUOTE(White850T5 @ Apr 9 2005, 01:14 PM)
My attempts to follow the vacuum lines coming out of this doohicky were unsuccesful. I have no idea where the canister is.
Maybe the valve I got just doesn't work for S70s? It's radically different than the one I took off.
That's the one I took off. Compare to the pictures of the new one I posted previously.
#29 Bay13
Bay13
  • 6,378 posts
Posted 09 April 2005 - 07:07 PM
The part number thats on your correct valve is the 8627005, thats what you need, that number superceeds to a 9125243, order that part number.
#30 Nebor
Nebor
    TEAM BRAKE LUNCH
  • 3,472 posts
Posted 10 April 2005 - 12:33 AM
QUOTE(Bay13 Admin @ Apr 9 2005, 02:07 PM)
So howcome I have a 1998 model, and the fcpgroton site says "For 1998 S70s only?"
#31 Bay13
Bay13
  • 6,378 posts
Posted 10 April 2005 - 01:39 AM
Because the kind you are suppose to use depends on your emissions code.
#32 Nebor
Nebor
    TEAM BRAKE LUNCH
  • 3,472 posts
Posted 10 April 2005 - 01:48 AM
QUOTE(Bay13 Admin @ Apr 9 2005, 08:39 PM)
Any idea why this other one doesn't work? Different levels of vacuum involved or something?
#33 Bay13
Bay13
  • 6,378 posts
Posted 10 April 2005 - 01:51 AM
I have no Idea why a part not made for your car doesn't work.
In the future check for a part number on your part and then give them a call to avoid these problems. Not all parts people know the right questions to ask.
#34 Nebor
Nebor
    TEAM BRAKE LUNCH
  • 3,472 posts
Posted 10 April 2005 - 02:15 AM
QUOTE(Bay13 Admin @ Apr 9 2005, 08:51 PM)
That's the thing, I ran the part number on my old part through Volvo's computerized part catalogue. It recieved no hits. Then you tell me that the part number changed, and that I have to use the old number for ordering. How was I to know that to begin with?
#35 Bay13
Bay13
  • 6,378 posts
Posted 10 April 2005 - 02:20 AM
You arn't, it's not your fault. You are not a technician or a parts person. The tech would have told them the year and model and the "square" evap valve if they tried to give the round one. A good parts counter would ask what the emissions code was. All things that didn't happen here but you can get ahold of them and suggest that in the future they ask for the emissions code so you can get the correct part.
#36 Nebor
Nebor
    TEAM BRAKE LUNCH
  • 3,472 posts
Posted 10 April 2005 - 02:27 AM
Think they'll take back the wrong one? Or am I gonna have to shell another $17.50 for the new style one? I emailed Nick about it and hopefully I'll hear back on Monday.
#37 Bay13
Bay13
  • 6,378 posts
Posted 10 April 2005 - 03:31 AM
They should be willing to correct the problem.
#38 sp5368
sp5368
  • 686 posts
Posted 10 April 2005 - 03:46 AM
Gas cap I went through two generic before someone informed about buying the oem one and cell went out that was a waste of money wish I had known about this forum
#39 2005V70R
2005V70R
  • 175 posts
Posted 13 June 2005 - 12:49 PM
How often does a new OEM gas cap fix this problem? I have the P0455 code cleared and it keeps coming back.
2005 V70 R
1998 V70 GLT
"Took off the restrictor plate, gave the red dragon a little more juice"
#40 2005V70R
2005V70R
  • 175 posts
Posted 13 June 2005 - 01:07 PM
Also, anyone have a part number for an OEM fuel cap? FCP and Taylor and others carry STANT caps, not Volvo OEM.
2005 V70 R
1998 V70 GLT
