S70 Glt
7 replies to this topic
#1 amsmas51
amsmas51
  • 17 posts
Posted 29 March 2005 - 06:08 AM
First off, this is my first posting so im probablly doing it wrong but this is a great site. I have a 98' S70 and every one in a while at idle it will stumble, there arent any check engine lights on, and no performance mods, it has done it for about a year now, i havent notied any loss of power or gas mileage. I was just wondering if anyone could tell me what it is, also the front strut makes a squeeking noise. i appreciate your help. Adam
#2 gdizzle
  • 19,804 posts
Posted 29 March 2005 - 02:54 PM
QUOTE(amsmas51 @ Mar 29 2005, 12:08 AM)
This will probably get moved to maintenance, but I would try cleaning the throttle body. Rich or Winkey will point you in a better direction.
#3 jda2000
jda2000
  • 1,027 posts
Posted 29 March 2005 - 03:05 PM
Clean the throttle body and the IAC motor. That will fix your rough idle most likely
John, Sarasota, FL
'01 V70 T5, '07 S60 2.5T
#4 550
550
    someone please talk to me
  • 10,273 posts
Posted 29 March 2005 - 03:58 PM
Sadly, this topic had been covered hundreds of times. There was a technical service bulletin put out about a year ago now. It explained that the ECM needed a re-flash from the dealer.
http://volvospeed.com/vs_forum/index.php?showtopic=15862
check that
and this
http://brickboard.com/AWD/index.htm?id=776419 <--- this is the t.s.b.
good luck.
#5 Bay13
Bay13
  • 6,378 posts
Posted 29 March 2005 - 04:58 PM
Stumble could be from a dirty Throttle body, and IAC motor, but it can also be from the need for new plugs, cap and rotor, and maybe wires.
#6 MrWinkey
MrWinkey
    Am I drunk? You tell me!
  • 4,759 posts
Posted 29 March 2005 - 11:57 PM
QUOTE(gdogg16 @ Mar 29 2005, 09:54 AM)
jda2000 and yourself seem too do very well in pointing people in the right direction also cool.gif ..we don't have to answer everything all the time?
"SMOKE TROUT NOT CRACK"
#7 Kashif
Kashif
  • 1,846 posts
Posted 30 March 2005 - 01:42 AM
QUOTE
Could be that spring seat or even spring mount are beginning to fail. The only way to really know for sure would be to remove the strut from the Car. But if you do that you will ruin the alignment. Usually this sort of thing is taken care of when one changes the struts and shocks of their car.
#8 2005V70R
2005V70R
  • 175 posts
Posted 30 March 2005 - 02:44 PM
QUOTE(550 @ Mar 29 2005, 11:58 AM)
check that
and this
good luck.
Yes...get the ECU reflashed with the Motronic upgrade from the dealer
2005 V70 R
1998 V70 GLT
"Took off the restrictor plate, gave the red dragon a little more juice"
