i hear this occassional grinding/scraping noise coming from the front right when i brake, usually most noticeable when downhill with moderate brake pressure and nearing the end at around 20 mph-0. i took off the rims and checked the rotors, calipers, and pads..i don't see any noticeable abnormal wear. don't hear it on acceleration. and it isn't always there.
could it be the shaft? cv? hub? or still just a brake problem?
Occasional Grind Noise Front Right When Braking
Started by steve s, Apr 01 2005 01:54 AM
7 replies to this topic
Posted 01 April 2005 - 03:17 AM
Check to make sure that the brake rotor dust shield is not bent and rubbing on the rotor.
<insert witty comment here>
Posted 01 April 2005 - 12:17 PM
Sometimes when you have new pads on old rotors, the pads will make noise breaking into and seating on the old rotors. Do check the dust shield.
Posted 01 April 2005 - 06:50 PM
pads are used/half-thru...and there is no dust shield for the 13" brembos
Posted 09 May 2005 - 01:15 AM
took a closer look...the pads were pretty much done, probably 1mm of grove left on the pads. got new ones, and viola, no more grinding. interestingly, the pads are not evenly worn for each caliper as well as for left and right calipers...the right one wore out faster..
Posted 09 May 2005 - 05:47 AM
must be all that hard left cornering you do or something, or maybe all the mountain curves out there in SF generally turn left!!
Posted 09 May 2005 - 07:21 AM
hmm...come to think of it.. there is a corner on the otherside of my block that i take pretty fast when i come home sometimes.. all one way streets, and i have to turn left to go around the block. heheh
