Bulb Failure Warning Light - Hid Lights
19 replies to this topic
#1 drPheta
drPheta
  • 2,108 posts
Posted 12 April 2005 - 04:52 AM
When you install HID lights, the car thinks your bulbs are out because the HIDs run off of 35 watts, rather than 55 watts. Right?
So, how did you guys get around this? Wasn't there something to do with the relay? I can't seem to find the thread that contained that information.
1995 Cream Yellow 850 T-5R Wagon (sadly has been sold)
Selling the following: Check the Classifieds: CF goodies | 18" BBS Tritons with GoodYear Eagle GS-D3 F1 Tires | Stage 1 Stuff | Some other odds and ends.
#2 Zappo
Zappo
    The One Upper
  • 15,529 posts
Posted 12 April 2005 - 04:58 AM
QUOTE(drPheta @ Apr 11 2005, 09:52 PM)
It determines a bulb is out by measuring the draw difference between the left and right sides of the car. If the difference is high enough, the light comes on.
If you only put the HID in one headlight, it will trigger the light. If you put them in both, everything is balanced and no light, except on the road! smile.gif
#3 dancetheman
dancetheman
  • PipPipPipPip
  • 3,355 posts
you could always go ghetto and take the bulb out...throwing it out as a last ditch effort
daniel (@) volvospeed.com
Present:
2007 Candy White GTI
Previous:
1995 Yellow 854 T5-R
#4 theunderlord
theunderlord
  • PipPipPipPipPipPip
  • 14,738 posts
Posted 12 April 2005 - 03:50 PM
This is a misnomer, properly installed HID's will NOT trigger the idiot light to go on.
#5 StickThatClutch
StickThatClutch
    Icey Hott Stunna
  • 6,188 posts
Posted 12 April 2005 - 05:19 PM
Depends on the system. Seems the P1 cars do some sort of relative efficency monitoring. While the P2 compare to absolute values.
You can always wire in a resistor if you're worried.
IPB Image
StephenIPB Image
#6 HPTDoh
HPTDoh
  • Validating
  • 5,969 posts
Posted 12 April 2005 - 05:30 PM
How easy are HID's to install?.. I'm probably gonna buy whitecw's lights, but I've never installed new ballasts or whatever theyre called.
#7 StickThatClutch
StickThatClutch
    Icey Hott Stunna
  • 6,188 posts
Posted 12 April 2005 - 05:35 PM
QUOTE(PikeyTheTurtle @ Apr 12 2005, 09:30 AM)
Figure where you want to mount the ballast and plug in the wire harness(es). Good to go. 15-30 minute process. Depends how much of a turtle you are.
Good luck.
IPB Image
StephenIPB Image
#8 theunderlord
theunderlord
  • 14,738 posts
Posted 12 April 2005 - 05:44 PM
QUOTE(PikeyTheTurtle @ Apr 12 2005, 10:30 AM)
you're gonna need bulbs! let's talk.
#9 HPTDoh
HPTDoh
  • Validating
  • 5,969 posts
Posted 12 April 2005 - 05:47 PM
QUOTE('98S70R @ Apr 12 2005, 12:44 PM)
hahaha.. pm already sent
#10 StickThatClutch
StickThatClutch
    Icey Hott Stunna
  • 6,188 posts
Posted 12 April 2005 - 05:51 PM
K-dawg... Pikey has a 850 you have H7 capsules... not a match made in heaven? sad.gif
IPB Image
StephenIPB Image
#11 theunderlord
theunderlord
  • 14,738 posts
Posted 12 April 2005 - 05:57 PM
QUOTE(StickThatClutch @ Apr 12 2005, 10:51 AM)
no sir.. he's rockin 9006 IIRC.... sad.gif so sad..
#12 maiku
maiku
  • 9,671 posts
Posted 13 April 2005 - 12:45 AM
spliceage!
MAKE the H7 bulbs work!
#13 HPTDoh
HPTDoh
  • Validating
  • 5,969 posts
Posted 13 April 2005 - 03:47 AM
Something went over my head...
#14 Serge
Serge
    Level 6 Senior Member
  • 10,667 posts
Posted 13 April 2005 - 04:17 AM
You can add a dummy load to compensate for the lower current drain. I would use a DMM in series to measure how many amps are drawn with a regular halogen and then with the HIDs. Subtract the two and you will know the amount extra current you need to drain.
Using the formula R = V/I; where R = resistance we want, V = voltage of the circuit (12V), I = current drain.
So given a halogen bulb drew 4.5 amps (55W @ 12V, 55/12 = 4.5834) and we'll say a HID ballast draws 2.9 amps (35W @ 12V, 35/12 = 9.167), the difference is 1.6 amps.
R = 12/1.6 = 7.5ohms. You'll need a large 7.5 ohm resistor, atleast 18 watts.
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...sspagename=WDVW <-- this might suffice.
Serge - 95 850 T5
#15 volvo4lif3
volvo4lif3
  • 1,323 posts
Posted 13 April 2005 - 04:24 AM
And kevin your wrong, properly installed HID kits will trigger the dipped beam light to come on. My hids are installed correctly, and my light comes on constantly. http://www.xenonvalot.com/xenonfixvolvo.html Read here. I would also fix my light, but i dont know where to find the CEM. sad.gif
05 s60 2.5T
#16 Slater
Slater
    Quickbrick Motorsports
  • 3,198 posts
Posted 13 April 2005 - 04:55 AM
QUOTE(volvo4lif3 @ Apr 13 2005, 12:24 AM)
What a PITA. I just pulled my cluster bulb, Problem solved.
I'm not an idiot who needs to know when my turn signal or brake lights are out. I have eyeballs for that.
#17 theunderlord
theunderlord
  • 14,738 posts
Posted 13 April 2005 - 03:46 PM
QUOTE(volvo4lif3 @ Apr 12 2005, 09:24 PM)
haha, maybe it's a 850 vs 70 series thing, cause my old lights were installed incorrectly, and the light came on, new lights... installed correctly... no idiot light.
#18 Serge
Serge
  • 10,667 posts
Posted 13 April 2005 - 06:31 PM
QUOTE(volvo4lif3 @ Apr 12 2005, 10:24 PM)
CEM is under the dash (driver's side).
Serge - 95 850 T5
#19 Slater
Slater
  • 3,198 posts
Posted 14 April 2005 - 01:26 AM
QUOTE(LiquidKernel @ Apr 13 2005, 02:31 PM)
What about on 850s?
#20 Serge
Serge
  • 10,667 posts
Posted 14 April 2005 - 01:42 AM
QUOTE(Slater @ Apr 13 2005, 07:26 PM)
What about on 850s?
Our Central Electrical Unit is also under the dash. However, the bulb failure system is located in the trunk, opposite of the gas filler door. I haven't played with it, but I have a spare one in the garage.
Serge - 95 850 T5
