Detailing
#1 Guest_Guest_*
Posted 13 April 2005 - 09:44 PM
Posted 13 April 2005 - 09:52 PM
man, someone else run that IP and tell me what you see.
Posted 14 April 2005 - 02:32 AM
Posted 14 April 2005 - 02:57 AM
Posted 14 April 2005 - 03:02 AM
Posted 14 April 2005 - 03:13 AM
Posted 14 April 2005 - 03:57 PM
yup.... we are watching you.
Posted 14 April 2005 - 06:12 PM
Engine: K&N Air filter
Wheels: 16" V70 Persus Wheels, 205/55/16 Michelin Pilot
Other: E-code headlights, tints
My Webpage
Posted 14 April 2005 - 06:35 PM
Unless you're a nut and use souveran signature on your car. Then you can use your hands, literally.
EST Intake, 16T @ 15psi, Forged Rods, Speedtuning ECU, iPD HD TCV, iPD Cat-Back, Strut Brace, Bilstein HDs, iPD Grille, Jewel Headlights, 17" Canistos, 215/45/17 Kumho ASX Tires
Posted 14 April 2005 - 07:21 PM
Posted 14 April 2005 - 07:26 PM
Team Beverage - Vice Prez
Posted 14 April 2005 - 07:32 PM
hand polishing isnt poishing at all, its just waxing, if you have swirls in your paint you have to use a buffer to gett them out, with waxing them you might hide them but they will come back shortly
#14 Guest_UnsanePyro_*
Posted 15 April 2005 - 03:06 AM
#15
Posted 15 April 2005 - 07:15 PM
oh and it also fills in small little scratches takes swirls out a little as well
Edited by 850Boyo, 15 April 2005 - 07:16 PM.
#16
Posted 15 April 2005 - 07:54 PM
u will never get rid of swirls doing it by hand, your have to use a buffer if you want them to be gone, i've been a professial detailer for 5 or so years now!
#17 Guest_Guest_*
Posted 16 April 2005 - 04:10 PM
#18
Posted 16 April 2005 - 04:52 PM
what kinda buffer do you have? there are high speed ones and a slow speed one, i guessing you have the high speed one cuase you worried about burnig paint, which can happen! but if you just keep the pad falt on the car and stay away from edges you should be fine, as for what pad to use. depends, if the car is really monkeyed then a whool pad is needed, but if you jsut wanna bring out more of a sine a yellow foam pad is waht you need, the compound is the important part. if your using the foam pad you dont want anything agrisve at all
sorry for the spelling!
Jake
#19 Guest_Guest_*
Posted 18 April 2005 - 05:17 PM
#20
Posted 18 April 2005 - 05:23 PM
an autobody supply store.
