Oem Fog Light Switch
22 replies to this topic
#1 Gregg
Gregg
    daniel stern lighting pimp
  • 2,611 posts
Posted 17 April 2005 - 04:16 AM
So I was playing around the other day, trying to get my fog lights to come on all the time...touched a couple of wires together, got some smoke, and now my fog lights do not come on. The fuse is still good (i.e. it did not blow); the light for the fog light picture on the switch comes on; but when I flip the switch to the ON position, the rectangular green light does not come on, nor do the fog lights.
Is the switch garbage? Or is there something else I should be looking at? I am going to try my brother's fog light switch tomorrow and see what happens.
#2 merlin390
merlin390
  • 2,778 posts
Posted 17 April 2005 - 04:45 AM
might have fried the relay?
#3 maiku
maiku
  • 9,671 posts
Posted 17 April 2005 - 04:47 AM
switches usually don't break (unless you melted the contacts or something)
i agree it is probably the relay
#4 prasamin
prasamin
    Bipedal Magnaflux
  • 16,242 posts
Posted 17 April 2005 - 06:28 AM
hopefully it's the relay, but it could be the actual wiring from the switch to the relay.
#5 Gregg
Gregg
  • 2,611 posts
Posted 17 April 2005 - 06:42 AM
Is the relay part of the switch? Or is it located somewhere else in the dash or something? Is there a standard relay location?
#6 prasamin
prasamin
    Bipedal Magnaflux
  • 16,242 posts
Posted 17 April 2005 - 06:47 AM
I think there is a box of relays under the dash on the drivers side...finding the relay, however, is something I can't tell you about!
#7 maiku
maiku
  • 9,671 posts
Posted 17 April 2005 - 12:58 PM
relays are near the driver side firewall
it is a pita to get under there
#8 Bay13
Bay13
  • 6,378 posts
Posted 17 April 2005 - 01:57 PM
Take down the kick panel on the drivers side and the relay panel is on the fire wall out board and up. The fog relay is a "J" type relay and it's located top left on the relay board. (it could be labled 201) European models also use relay 213 bottom left on that same panel. Just to be sure the fuse is #18. You might turn everything on and see if you have power at the bulb.
#9 merlin390
merlin390
  • 2,778 posts
Posted 17 April 2005 - 02:06 PM
This is helpful, thanks Rich. I am trying to add factory fog lights to my 850 I put the switch into the dash wiring, and I got under there to look for a relay (which I know is missing) think you can provide the part number for that realy for us? please.
#10 Bay13
Bay13
  • 6,378 posts
Posted 17 April 2005 - 02:57 PM
Part number for the fog relay is 9130269
#11 merlin390
merlin390
  • 2,778 posts
Posted 17 April 2005 - 03:38 PM
thanks Rich, the dealer wanted 120ish dollars for that relay new.
#12 Bay13
Bay13
  • 6,378 posts
Posted 17 April 2005 - 05:33 PM
The J relay thats top left of the panel we were talking about further up the thread is a small simple relay, 1 x 1 inch. That price sounds too high, try
http://www.FCPgroton.com
If you can't find it as aways give them a call and quote the part number you want.
#13 merlin390
merlin390
  • 2,778 posts
Posted 17 April 2005 - 11:24 PM
I found a place selling them used, I will call FCP in the morning but here is the place that has them used ALL the way at the bottom of the page.
#14 a_place_08
a_place_08
  • 90 posts
Posted 17 April 2005 - 11:31 PM
heres my .02 bits
go get current tester *thats what i call he little screwdriver witht the pointy end and a light in the middle that has an alligator clip to go to a ground wire* and test the wiring before you replace anything, it will save you money and a headache if that is what is wrong. hence you wont have to fix your relay just to find out you have a dead wire. find the dead spot in your wire and either replace it with the same wire from your hardware store or see if you can splice the wire.
1995 volvo 850 turbo
--vacuum lines redone--hosetechniques.com universal kit
--open air filter intake--k&n flowcharger filter-custom hosing to ram air port
--optima red top remounted at 90degrees from origional position
--dist/rotor/spark plug& wires --ipd.com kit and bosch perfo. wires
user posted image
PAC NW REPRESENTIN!!!!
Adam place
Blaine, WA 98230
#15 merlin390
merlin390
  • 2,778 posts
Posted 18 April 2005 - 12:17 AM
Get a pin out of the wires in the switch, and a pin out of the wires at the relay and start checking for current with your test light probe. Also a good wiring diagram would help you trace wires.
#16 Gregg
Gregg
  • 2,611 posts
Posted 22 April 2005 - 12:08 AM
so today I checked for power at the bulb, and no power there. Since the switch still lights, is it most likely the relay then?
There are a bunch of relays under the fuse panel box (remove the 4 screws at the corners to gain access to it). Is this where the fog light relay is located? I noticed that there were (I think) three J relays with the same p/n that Rich listed above. I am just wondering what these relays are for, if not for the fog lights.
#17 Gregg
Gregg
  • 2,611 posts
Posted 23 April 2005 - 09:29 PM
QUOTE(gmischenko @ Apr 21 2005, 08:08 PM)
bump
#18 merlin390
merlin390
  • 2,778 posts
Posted 24 April 2005 - 02:09 AM
bump.
#19 Gregg
Gregg
  • 2,611 posts
Posted 24 April 2005 - 11:43 PM
QUOTE(Bay13 Admin @ Apr 17 2005, 09:57 AM)
Is there an easier way to access the relay? For instance, can the whole relay panel and fuse box be pulled straight up once the hood is open? I tried crawling down under the driver's kick panel, and I can barely see the relay, let alone try and reach it to release it and put a new one in. If the relay panel doesn't go up, does it slide down at all?
#20 Gregg
Gregg
  • 2,611 posts
Posted 25 April 2005 - 06:11 AM
Ok, so I figure out how to gain easy access to the relay panel. But Rich, the spot onthe board you referred to does not have a fog light relay, according to VADIS
This second picture (below) shows the other relays located underneath the fuses...form what I can tell, there is only one lighting relay...the 104/108 main lighting relay
So is it the main lighting relay that I want to replace in order to get my fogs to work again (assuming that it is the relay that is bad)?
Edited by gmischenko, 25 April 2005 - 06:12 AM.
