Additional Lights
14 replies to this topic
#1 Asinine
Asinine
    Team GKT
  • 2,462 posts
Posted 17 April 2005 - 06:22 PM
I've heard that for some reason Volvo produced the 850 pre-wired for marker lights (i'm sure you all know but for clairty, they would be just behind the front tires where it says "Volvo".
If that's the case then, cool.
More importantly, is the 850 (i have a '94 Turbo) pre-wired for fog lights. I don't know if that was an option, but it's one i'd like.
If it isn't how difficult is it to put some stock looking ones in, and wire them to the dash where they would have existed originally?
'97 855 T5 - DEAD! '04 XC70 2.5T AWD - Current Whip
MY BLOG
I take wikd pics - Summit Photography
#2 Serge
Serge
    Level 6 Senior Member
  • 10,667 posts
Posted 17 April 2005 - 06:27 PM
850s should be pre-wired for fogs.
Serge - 95 850 T5
#3 Deltablade
Deltablade
  • 1,661 posts
Posted 17 April 2005 - 06:44 PM
oops...
Edited by Deltablade, 17 April 2005 - 06:44 PM.
Tom
1995 850 GLT
#4 exexpat
exexpat
    Projector Gadget
  • 7,428 posts
Posted 17 April 2005 - 07:57 PM
QUOTE(Asinine @ Apr 17 2005, 11:22 AM)
My '96 wasn't, but I wired mine to the corners in about an hour. (less time than needed to clean the residual adhesive from the Volvo emblems)
I'm "X to the P" and I've been pimped...
I use www.airbagit.com for air ride and www.motorsport-tech.com for custom adapters and I like them both
#5 Burgundy_850
Burgundy_850
  • 365 posts
Posted 17 April 2005 - 08:01 PM
You can check if your sidemarkers are prewired, it's really easy. Open your driver's side door all the way, and look at where it hinges, towards the front of the car. You should see an opening where you can peer through (might need a flashlight). If you see wires going up to where your Volvo emblem is, you're prewired.
user posted image
#6 Volvoson
Volvoson
    Baby On Board Racing
  • 17,264 posts
Posted 17 April 2005 - 09:24 PM
QUOTE(LiquidKernel @ Apr 17 2005, 11:27 AM)
Really? ohmy.gif Where can you look to see?
View Postgdizzle, on 21 May 2012 - 03:52 AM, said:
All the clean cars are in the PNW.
#7 T5BRICK
T5BRICK
  • PipPipPipPip
  • 3,899 posts
Posted 17 April 2005 - 09:44 PM
QUOTE(854_Turbo @ Apr 17 2005, 02:24 PM)
i'm guessing you could see if you removed the plastic splash pan under the front of your car.
'06 Mazda3
#8 Deltablade
Deltablade
  • 1,661 posts
Posted 18 April 2005 - 02:12 AM
QUOTE(felix88 @ Apr 17 2005, 03:44 PM)
Does anybody know if they were wired for the switch?
Tom
1995 850 GLT
#9 maiku
maiku
  • 9,671 posts
Posted 18 April 2005 - 02:26 AM
mine is prewired for fogs
just need to get the relay
#10 T5BRICK
T5BRICK
  • PipPipPipPip
  • 3,899 posts
Posted 18 April 2005 - 05:38 AM
'06 Mazda3
#11 merlin390
merlin390
  • 2,778 posts
Posted 18 April 2005 - 06:49 AM
I dont think any of the US spec cars were prewired for side markers but they are prewired for fogs
#12 T5BRICK
T5BRICK
  • PipPipPipPip
  • 3,899 posts
Posted 18 April 2005 - 07:09 AM
Edited by felix88, 18 April 2005 - 07:10 AM.
'06 Mazda3
#13 maiku
maiku
  • 9,671 posts
Posted 18 April 2005 - 07:11 AM
it is not hard to wire it yourself
took me all of 10 minutes to do
#14 Serge
Serge
  • 10,667 posts
Posted 18 April 2005 - 07:31 PM
QUOTE(Deltablade @ Apr 17 2005, 08:12 PM)
Yes sir, they are. If you look under the kick panel you'll find a yellow harness that's not connected to anything.
Serge - 95 850 T5
#15 maiku
maiku
  • 9,671 posts
Posted 18 April 2005 - 07:34 PM
actually, if you look on the left of the steering wheel, in one of the blank dash switch places, the harness should be there
