OK, this has been sort of buggin me a bit recently: I step on the brake pedal after I haven't used it in a bit and there is a bit of squishiness at the top of the pedal that firms up quickly as I push it. No problem braking. The thing is that if I come off the pedal and get back on it quickly, it seems to firm up higher in the pedal stroke. Each time I come off and on again quickly it stay consistent, but once I lay off it for a bit and get on it, I get that squishiness again.
I am pretty positive that it's not the master cylinder, as the pedal doesn't sink when I'm stopped at a light or anything (once I reach the firmness, it stays firm). I'm wondering if the vacuum booster may be losing efficiency or something. Is there a line or elbow or something that's known to degrade over time?
Anyone else notice this when they brake?
Brake Pedal Action
Started by AJU, Apr 21 2005 02:49 PM
6 replies to this topic
Posted 21 April 2005 - 02:49 PM
1996 855 N/A Manual
Posted 21 April 2005 - 03:35 PM
could be degraded brake fluid or air in the system. Time to flush
John, Sarasota, FL
'01 V70 T5, '07 S60 2.5T
Posted 21 April 2005 - 04:56 PM
Hey I have the exact same ting with my 96 855 turbo....
It will be interesting to see what you find.
Ben
Ben
1996 850 Turbo.....5 Speed Stick
Posted 25 April 2005 - 09:52 PM
My dads car (95 850 turbo) had that right after we replaced all the rear brake components and power flushed almost 4 quarts through the system.
So if anyone has any ideas that would be great.
1996 850R Black with black interior. w/ 94K miles - B+G Springs with Bilstein HD struts and shocks, Bridgestone Potenza SO-3's 215/45/17 on Volans for the summer, and Dunlop Graspic DS-2's 195/60/15 on Volvo 15" steel wheels for the winter. K&N Filter, Clear side markers, E-code Lenses and E-code 2-bulb corners.
Posted 26 March 2006 - 08:52 PM
I'm having the same problem with my 96 850 turbo. When I press it the first time it travels lower than when I repress it again. The brake pedal does not sink to the floor. Anyone knows why?
Posted 27 March 2006 - 12:19 PM
I'm pretty sure that the reason this happens is that the distance one of the pads has to travel to contact the rotor is greater than the other(s). When you press the brake pedal, one pad makes contact with the rotor and then the other takes a moment longer, leading to the squishy feeling. It takes some time for the pads to return - so if you press the pedal again, the pads are relatively equal in terms of distance from the rotor and they make contact together, no squishy feeling.
I haven't noticed this recently at all - but I haven't done anything to "cure" it. I think it's just a wear thing.
1996 855 N/A Manual
