Was getting an intermittant CEL with code P0171 (bank one too lean). Replaced the MAF as recommended here but still getting CEL with code P0171. Reset and it comes back in about a week.
Other info I have pulled when the fault occurs with my ScanGauge reader as follows:
PID02=0171
PID02=0100 loop is open
PID04=LOD14
PID05=7E Water temp 186F
PID06=6A
PID07=9C
PID0B=1B
PID0C=08F9 MAP PSI 3.9
PID0D=32 31 MPH
Any ideas?
Thanks,
Jeremy
Cel Light Still On After New Maf
Started by Tiger Moth, Apr 27 2005 01:35 AM
Posted 27 April 2005 - 01:35 AM
'87 740T Wagon 250+k and still going strong
2K V70 Wagon 2.4 non turbo
Posted 27 April 2005 - 11:47 PM
You have an 0171 and just replaced the amm??......did you even look for a vacuum leak say on the end of the intake by the P/S pump....Sounds like that's where the problem lies..
"SMOKE TROUT NOT CRACK"
Posted 09 May 2005 - 03:09 PM
QUOTE(MrWinkey @ Apr 27 2005, 04:47 PM)
The funny part is I looked at my old engine/manifold and saw the plug on the end of the manifold but it was plugged so I assumed it was a judt a hole for machining the inside and just capped off.
Anyone need an AMM? I have an extra as well as another engine too.
Jeremy
Edited by Tiger Moth, 09 May 2005 - 03:09 PM.
Posted 10 May 2005 - 12:36 AM
I like the rooster..but did it fix the problem...I'm not Sherlock Winkey here...I can't figure out what everyone drives..just looking at the code and complaint?
