Synthetic Oil
Posted 29 April 2005 - 03:52 AM
Posted 29 April 2005 - 03:54 AM
Posted 29 April 2005 - 08:29 PM
DEWFPO
Posted 29 April 2005 - 08:41 PM
Posted 29 April 2005 - 08:45 PM
Yes it can and does happen, but not every time. It's a risk you take if you want to run your car on a better oil.
I ran my old engine on semi-synth (or blend) as I didn't want to cause leakage as the car had done 120,000 miles. However, after that engine blew and I got a new engine, I'm using fully synth as this engine only has 60,000 on the clock.
With 90,000 miles I'd say go for synth oil, and if you get leaks then get them sorted - they will happen sooner or later anyway, the syth oil will only accelerate them at worst.
Posted 29 April 2005 - 08:53 PM
-Petri (Val)
Posted 30 April 2005 - 03:31 AM
2001 Pewter Z28 M6. !engine. Something mean, wicked, and nasty is being swapped in soon.
1997 Volvo 850 GLT Now with T5! Hooray, the daily driver is alive!
Posted 30 April 2005 - 04:15 AM
Volvospeed On Google+
Posted 30 April 2005 - 04:50 AM
my car's always been on dino, and i just bought it and today changed the oil. i considered syn but i don't want to get leaky seals or anything like that. i don't see why it's worth me spending way more money on syn oil, if i'm going to continue to do a regular oil change every 3k miles. i have time to do it, so i don't see what the big deal is if the only reason is to change it at 3k with dino or 5k or whatever with syn
Posted 30 April 2005 - 04:56 AM
Your car is turbo and you upped the boost. I have sent Mobile 1 tri-syn out with 3k and it came back with very high oxidation. And thats a semi-syn Dino oil can break down in hours depending on what your doing to it.
Posted 30 April 2005 - 05:03 AM
i switched at 93k miles, and i still have a tiny leak. it may just be my oil return line gaskets and seals, which i am replacing during my next oil change.
Posted 30 April 2005 - 05:04 AM
Posted 30 April 2005 - 05:41 AM
#14
Posted 30 April 2005 - 03:49 PM
#15
Posted 30 April 2005 - 03:54 PM
And CostCo has some of the best prices on Mobil 1, it's under $25 for a six pack.
#16
Posted 30 April 2005 - 05:12 PM
At 90,000 miles, I'd do an Auto-Rx cleaning with conventional oil, then use either conventional or synthetic as you choose.
Ken
#17
Posted 30 April 2005 - 06:32 PM
-Petri (Val)
#20
Posted 30 April 2005 - 06:45 PM
I just changed my oil at 8k.
Edited by FINN, 30 April 2005 - 06:45 PM.
-Petri (Val)
