How Often Do You Change Your Oil?
26 replies to this topic
Poll: How often do you change your oil? (82 member(s) have cast votes)
You cannot see the results of the poll until you have voted. Please login and cast your vote to see the results of this poll.
Vote
#1 VolvoT5
VolvoT5
  • 717 posts
Posted 30 April 2005 - 06:44 PM
Vote!
#2 T5BRICK
T5BRICK
  • PipPipPipPip
  • 3,899 posts
Posted 30 April 2005 - 06:45 PM
every 3k miles.
'06 Mazda3
#3 merlin390
merlin390
  • 2,778 posts
Posted 30 April 2005 - 06:59 PM
no more than 5000 miles max. I read it on here that after 4000miles the crap in the oil more than doubles. and a customer who brings his car in for service showed me two lab reports on his car '04 Taurus one oil change at 6000 miles and one at 4000 miles the levels of stuff they found had more than trippled
#4 VolvoT5
VolvoT5
  • 717 posts
Posted 30 April 2005 - 07:02 PM
QUOTE(merlin390 @ Apr 30 2005, 07:59 PM)
Dino or synth?
#5 merlin390
merlin390
  • 2,778 posts
Posted 30 April 2005 - 07:04 PM
ford motorcraft 5w20 semi-sythetic
I change mine every 3500-4000 with Motorcraft 5W30 synth-blend (its free I dont complain)
Edited by merlin390, 30 April 2005 - 07:05 PM.
#6 Che'_Moderator
Che'_Moderator
    Monkey Master
  • Admin
  • 24,209 posts
Posted 30 April 2005 - 08:06 PM
QUOTE(merlin390 @ Apr 30 2005, 01:04 PM)
Motul 300v every 3k miles or 6 months.
#7 Mesoam
  • 18,673 posts
Posted 30 April 2005 - 09:06 PM
semi synthetic (high milage) Mobil 3k
96 854 R, CLICK ME
The Jeep
#8 WhiteT5
WhiteT5
    Sampson
  • PipPipPipPip
  • 4,828 posts
Posted 30 April 2005 - 09:25 PM
QUOTE(Volvospeed Admin @ Apr 30 2005, 02:06 PM)
How ya like the Motul Charles? Great stuff if I must say so myself. Whenever I order it though, the cans always come dented. Oil costing $10/quart should not come in dented cans mad.gif .
blink.gif Your poll is flawed. What if someone changed their oil at 3500 or 6500 miles?
I change mine usually a bit before 3500 miles with Motul 300V 5w-40 or Voll Synthese 5w-40.
- Sean
#9 VolvoT5
VolvoT5
  • 717 posts
Posted 30 April 2005 - 10:17 PM
QUOTE(White850T5 @ Apr 30 2005, 10:25 PM)
You round up or down. Most people won't change exactly on the mile. Most will say "3000" or "4000", not "3500" !!
I could have done 0 - 2,999, 3,000 - 4,999 etc, but thought that was a bit over the top!
#10 MrWinkey
MrWinkey
    Am I drunk? You tell me!
  • 4,759 posts
Posted 30 April 2005 - 11:25 PM
Castrol or Valvoline every 3 or 6mths which ever comes first(my own personal cars that is)
"SMOKE TROUT NOT CRACK"
#11 gatlin
gatlin
  • 141 posts
Posted 01 May 2005 - 01:12 AM
Castrol GTX High-Mileage 5W-30 every 3,333 miles.
Gatlin
'98 S70 T5 - 223K miles
'04 XC90 T6 - 70K miles
#12 VolFan
VolFan
  • 925 posts
Posted 01 May 2005 - 01:50 AM
Mobil 1 10W40
Every 4,000 miles with Mobil 1 Filter
1997 850R
204,000 and climbing"daily driver"no paint work!
SpeedTuning 17psi ECU/Supersprint 2.5" Exhaust/Custom 2.5" Polished down pipe
Weitec springs/IPD sway bars/Bilstein HD's/QuickBrick links
Stainless Brake Hoses/OEMPads/ Volans with Machined Lip
Kumho ASX 215/45/17'
#13 James A Sousa
James A Sousa
  • 307 posts
Posted 03 May 2005 - 02:36 AM
Like gatlin, every 3,333 miles - lines up on the 10,000 mile periods.
#14 Ceenit
Ceenit
  • 386 posts
Posted 03 May 2005 - 05:23 PM
every 4k-5k, the 5k is easiest to remember. I use dino on the volvo, Castol or Valvoline 10w-30 with the MANN filters
Edited by Ceenit, 03 May 2005 - 05:25 PM.
Chris
05 BMW 525
03 Acura MDX
94 Porsche 968 Cab
98 Volvo S70 T5 - Sold
#15 Guest_Guest_BREAKAWAY_*_*
Posted 03 May 2005 - 05:34 PM
volvo says 3000 to 3500 or three months.
#16 Guest_koza_*
Guest_koza_*
Posted 03 May 2005 - 09:01 PM
QUOTE(VolvoT5 @ Apr 30 2005, 06:44 PM)
Vote!
just to offset you all "miles" fellows
#17 bobcat
bobcat
  • 305 posts
Posted 03 May 2005 - 09:36 PM
6-8k which is about 5 months for me. dont do short drives ever really. use mobil 1 0w-40.
I read a good article on the mobil 1 that says only over 8k does the oil start to suffer with contaminats rising etc.
I also have an oil cooler which reduces the stress on the oil, but with engine oil its the engines nasty by-products that make changing necessary. Thats why atf can go 100k without a change if it stays at operating temps.
IPB ImageIPB ImageIPB Image
Volvo 850R Auto, 162K, Bobcat\SW Autos Custom Ecu, 18T, Reverse IC, 13 Row (Mocal Type) Engine Oil Cooler, 39 Row (3x 13 Row's)(Mocal Type) ATF Cooler, 20psi VDO Boost Gauge, Osram 50% Silverstars upfront, ITG Filter, OEM Strutbrace, Aerial Down Switch, 302mm Front Discs, Ferodo DS2500 Pads Front & Rear, Goodridge SS Brake Hoses, New Brake Hard Pipes, ATE Super Blue Brake Fluid, Koni Ajustables, Eibach pro kit, Slaters Link Rods, 4x Nankang NS-2 215/45/17 XL, Clear Side Repeaters, 70 Series Washer Jets, Powerflex Control Arm Bushes.
Fully Synthetic 5w-40 every 5K Miles, and flushed with 10l of Comma Dexron 3 ATF every other oil change.
In Progress: Custom Alu IC with 2.5" Core IC (Same Dimension as Stock one, Just thicker)
To Come: 3" Mandrel Bent down pipe and Cat Back.
#18 Tom
Tom
  • 185 posts
Posted 03 May 2005 - 11:33 PM
'94 850 wagon, N/A, automatic, 170K.
#19 Asinine
Asinine
    Team GKT
  • 2,462 posts
Posted 04 May 2005 - 01:15 AM
i change mine with penzoil high milage synth blend between 3 - 5k KMs.
'97 855 T5 - DEAD! '04 XC70 2.5T AWD - Current Whip
MY BLOG
I take wikd pics - Summit Photography
#20 Guest_whitecw_*
Guest_whitecw_*
Posted 04 May 2005 - 02:55 AM
Every 3,000.
