GrimVenom
Performance suggestions
Looking to upgrade my car a little bit, I’m planning on starting with a cold air intake, blow off valve, and possibly a stage 1 tune, any suggestions/products I should be looking for?
for what car?
best upgrades on a turbo car are exhaust, downpipe, intercooler and tune. You don't need a bov and the intake setups on these cars is decent
  • Similar Content
    • By jsf1992
      Hi all,
      Only recently has my 2010 S60 DAB radio stopped working.
      When I click on Radio on the central console and go on DAB 1 or DAB 2, nothing comes up on the main screen at all. It just put me back into FM mode after a few seconds.
      Does anyone have any idea how this could be fixed, any help would be much appreciated?
      Many thanks in advance
    • By zman172
      Box #1
      Steering wheel
      Trunk hatch carpeted trim
      Center console
      Box #2
      A/C compressor
      Windshield wiper motor
      Accelerator pedal
      Fuel door lock solenoid
      Navigation Antenna
      Ignition immobilizer
      Ignition switch starter
      Turn signal stalk
      Sensor alarm
      Seat belt restraints (x2)
      Door sill plates (x2)
      Metal radio pocket
      Volvo plastic radio pocket
      Radio
      A/C control unit
      Side view mirror left
      Servotronic fuse relay
      Trunk latch
      Windshield wiper stalk
      Overhead light driver front
      Rear bumper trim (x2)
      Dashboard trim
      Instrument border
      Rear speaker covers
      Driver motor seat controls
      Passenger motor seat controls
      Gear shifter
      Steering wheel column cover
      Center console trim (x2)
      Front cupholders
      Master cylinder
      Box #3
      Side view mirror right
      Fuel pump regulator
      Overhead dome light rear
      Windshield rain sensor
      Tan headrest with long spikes
      Rear armrest with cupholders
      Power steering pump tank
      Right upper brake light
      Right lower brake light
      Armrest for front seats
      Driver window switch box
      Front passenger window switch
      Airbag sensor
      Rear speakers (x2)
      Box #4
      Side airbags (x2)
      Spare tire
      Rear fuse relay box
      Rear third brake light
      Emergency brake with leather
      Rear trunk speaker trim (x2)
      Right rear trunk carpet trim
      Box #5
      All 4 door panels
      Rear bottom single seat
      Single seat leather upper
      Double seat leather upper
      Right front carpet
      Left front carpet
      Drivers front seat
      Passenger front seat
      Rear trunk hatch trim
      Box 6
      Braking systems (x2)
      Glove box
      Emergency brake trim (x2)
      Center console back plate
      Passenger lower dash cover
      Floor door trim (x2)
      Front door handles
      License plate frame
      Seat railing covers
      Box 7
      Instrument cluster 163000
      Radio trim
      Shifter trim
      Rain sensor cover
      Dash radio storage box
      Fuse panel cover
      Gas tank cover
      Front air bag crash sensor
      Rear air bag crash sensors
      Air bag impact sensor
      Headlight switch
      Hazard light switch
      Dashboard airbag
      Ecu
      Box 8:
      Miscellaneous
      On pallet not in box:
      Door pillar vents (x2)
      Torque rod
      Trunk pillar covers (x2)
      Left side skirt cover
      Right side skirt cover
      Trunk trim no cut out
      Dashboard
    • By ajck
      I'm in the UK and took my car for it's annual MOT test. The diff in the gearbox failed while they were road testing the car. It's a 2002 S60 2.0T, 89000 miles, manual gearbox, petrol. Obviously I want to minimise cost and a new gearbox would be very expensive. How do I minimise cost here - can the diff be replaced or repaired? (it's not something I can do). Could I find out the part number of the diff and buy a replacement from ebay (used is fine) and get someone to fit it?
      Any suggestions very welcome! I don't want to ditch the car as I just spent £700 on new suspension arms and MOT!
    • By DwayneCar
      New ro the Volvo thing. I've been looking at a s60 2.4t awd automatic parts car. I have an automatic s60 t5 right now. How compatible are the drivelines?
      Same trans control module?
      Rearend and drive shape bolt up?
      Ect.
      Thanks for any help, I'll continue to use the search engine and see what I can find
    • By DB855R
      2004 Volvo S60R MT 58k
      $8,000 Black with Gobi leather Every option except headed front seats and Navigation. All original no mods. Originally titled in Texas 3 owner car. After 19k car was bought by Stadel Volvo in East Petersburg Pa. Car was a certified per owned car when purchased by my father (2nd owner) Have window sticker. Throughout his ownership Volvo did all required maintenance. All brakes, rotors and pads were replaced prior to extended warranty running out. I purchased the car at 51k.  Since then Volvo replaced 2 rear hubs and did 4 wheel alignment. (Steering wheel they never centered it) At 54k I flushed the power steering fluid. I added IPD R style boost gauge.  All 4 tires were replaced with new Pirelli All season tires all have less then 2k. Custom wood insert with hinges was made for trunk to accommodate a full size spare. All 5 rims are 18x8 pegs with Pirelli tires 4 rims were painted dark grey (Have 18x8 bright silver pegs on my 740 if the grey color wasn’t for you) Also have original factory donut  Painted front grill black Car has carpet and formed rubber floor mats for front and rear   Minor accident Audi SUV brushed passenger front quarter fender Insurance paid for fender to be buffed out and resprayed to match total insurance cost was $1700 still have receipt   Great car, beautiful car not even a door ding in body. Issues: The display will show alarm service needed sometimes I don’t know why it locks and alarm works. Sometimes passenger window if u press up it will go up and come down about 1 inch Serpentine belt and tensioner and timing belt and tensioner are due to be replaced next year. Car is not close to replacement by milage but both are only 15 year belts.    Please note I can change the belts for right buyer it’s $350 in parts I’m asking a lower price knowing belts need future change    Only reason car has so little miles I have 7 vehicles Only reason for sale I have 7 vehicles  call or text: 5 seven 0 - 7 zero 9- four 33 nine. U can PM me but I’m rarely online
