Code
Started by sp5368, May 01 2005 09:35 PM
12 replies to this topic
Posted 01 May 2005 - 09:35 PM
Light is on and this code P0505
Posted 01 May 2005 - 10:19 PM
P0505 - Idle Control System Malfunction
Try cleaning out your idle air control valve and throttle body. It would also be a good idea to make sure you have a solid electrical connection on the idle air control valve.
- Sean
Posted 01 May 2005 - 10:22 PM
I have cleaned the TB is it same procedure for idle control valve,I just took a rag and cleaner
Posted 01 May 2005 - 10:27 PM
QUOTE(sp5368 @ May 1 2005, 04:22 PM)
It might be a bit difficult to do with a rag and clear on the IAC. I would suggest spraying a degreaser down in there being careful of the electrical connection and dry it out as best as you can, letting it air dry the rest of the way. It's possible that it could be some freak electrical jump in the system causing the code, but cleaning the IAC out certainly won't hurt anything.
- Sean
Posted 01 May 2005 - 10:29 PM
I will give it try thanks, Doug
Posted 03 May 2005 - 06:34 PM
I cleaned it out let it dry over night went for a drive and about 15 minutes later the code came up again IDLE air CONTROL VALVE. Is this something that over time wears out or is there something else I can try to make sure that it is the problem thanks. It idles very smooth around 1000/900 rpm better after I cleaned it ,Doug
Edited by sp5368, 03 May 2005 - 07:15 PM.
Posted 03 May 2005 - 11:47 PM
Clean it again with carb clean ...spray it down real good inside both holes ..don't be afraid to use the carb clean ...clear codes and try again...sometimes if there real nasty dirty and stuck it may take a cleaning or 2
"SMOKE TROUT NOT CRACK"
Posted 03 May 2005 - 11:54 PM
I sprayed the crap out of it and it is super clean but I will get it super super clean if thats what it takes.I pretty much cleaned until know more black stuff.
Posted 04 May 2005 - 12:04 AM
Get it super super super clean "clear codes" and try again
Posted 04 May 2005 - 12:10 AM
Okay suuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuper clean it is
Posted 04 May 2005 - 02:13 AM
if not.....replace it
Posted 04 May 2005 - 03:19 AM
Burn the car to the ground. My theory is that this is where it starts. Once you fix this problem, the car begins an endless cycle of turning on the Check Engine light days after you repair the last problem...
Posted 04 May 2005 - 03:27 AM
before
during
no code
