Oil Cap Leak
Started by with, May 02 2005 02:13 AM
11 replies to this topic
Posted 02 May 2005 - 02:13 AM
Has anyone else had oil come out around the oil cap? I'm guessing I need to replace it.
QUOTE (OrEo931 @ Feb 25 2008, 03:24 PM) <{POST_SNAPBACK}>
I didnt realize they awarded people for spitting at senior citizens and stabbing people. Interesting.
#2 Guest_mcevoyaaronc_*
Posted 02 May 2005 - 02:28 AM
dont need to replace the entire cap, just the o-ring on the cap.
Posted 02 May 2005 - 06:10 AM
The P/N for the gasket is 1275739.
Alex
Posted 02 May 2005 - 12:31 PM
Just changed mine...just the gasket.
Volvownage!
Posted 02 May 2005 - 01:30 PM
It may not just be the gasket... You may have a clogged PCV system. We don't have a PCV valve per se, but we have several lines running off the top of the head down to the intake and then around to an oil catch under the intake manifold.
It's a big PITA to get apart, but worth it. I recently cleaned and painted my intake. See pics below;
The intake thread
The vacuum hosee from the top of the valve cover to the intake (right by the turbo) was clogged. Actually, it was the nipple on the part that plugs into the intake pipe (looks like a tree) that was plugged with coked oil. I had to use a drill bit to clean it out.
Check to see if your dipstick is getting blown out of the tube... that's a pretty good indicator that it's not just the oil cap seal.
The intake thread
Posted 06 May 2005 - 06:02 PM
FCP has that seal for $0.69
Posted 07 May 2005 - 02:28 AM
My indie shop usually gives them to me.
Posted 07 May 2005 - 04:30 AM
I'm new to Volvo's, but from what I've read a clogged flame trap can also cause pressure to build up in the block,...which could possibly blow out cam seals/rear main seals. Tell me if I'm wrong.
Posted 07 May 2005 - 04:38 AM
QUOTE(adimichele @ May 6 2005, 09:30 PM)
Your right, to prevent this make sure the PCV is clean and change you oil at least every 5000 miles for a turbo charged car.
Posted 07 May 2005 - 05:16 PM
QUOTE(Kashif @ May 6 2005, 09:38 PM)
as far as i know, turbo cars do not have a flame trap.
maybe you were just saying that keeping the PCV system clean will prevent you from blowing your cam and rear main seals.
'06 Mazda3
Posted 07 May 2005 - 08:37 PM
QUOTE(felix88 @ May 7 2005, 10:16 AM)
Yeah thats what I meant, sorry.
Edited by Kashif, 07 May 2005 - 08:37 PM.
Posted 10 May 2005 - 02:24 AM
LIke I said,...i'm new to volvo's. Thanks...you just saved me time looking for a flame trap on my car.
