Does anyone else out there sell those rubber elbows that are used for the hard plastic vacuum lines?
Cheap Source On Those Vacuum Elbows?
Started by own6volvos, May 02 2005 04:40 AM
8 replies to this topic
Posted 02 May 2005 - 04:40 AM
96 855 GLT
01 V70 2.4i
01 V70 2.4i
Posted 02 May 2005 - 05:01 AM
FCPgroton.com could get you most OEM parts and their prices are among the lowest online, if not the lowest. Give 'em a call.
Posted 02 May 2005 - 07:39 PM
Posted 02 May 2005 - 08:44 PM
QUOTE(own6volvos @ May 1 2005, 10:40 PM)
I just use 4mm silicone hose. Rubber would works fine too. Rubber hose is about 30 cents a foot
Volvospeed On Google+
Posted 04 May 2005 - 04:03 PM
How many of each of the elbows in the diagram are in a car?
1996 850R Black with black interior. w/ 94K miles - B+G Springs with Bilstein HD struts and shocks, Bridgestone Potenza SO-3's 215/45/17 on Volans for the summer, and Dunlop Graspic DS-2's 195/60/15 on Volvo 15" steel wheels for the winter. K&N Filter, Clear side markers, E-code Lenses and E-code 2-bulb corners.
Posted 04 May 2005 - 04:08 PM
QUOTE(own6volvos @ May 2 2005, 12:40 AM)
You do realize that the elbows are like $2-$3 from Volvo? Can't get much cheaper than that.
Posted 04 May 2005 - 09:00 PM
QUOTE(Slater @ May 4 2005, 10:08 AM)
30 cents for enough rubber to make like 12 of them
Posted 04 May 2005 - 10:01 PM
QUOTE
it is different for every car, best bet is to go inspect your car and figure it out.
