Posted 03 May 2005 - 11:30 PM
I put those in a year ago (EST carbon fiber pads) with my front setup the backs do not do that much work I had to replace the front in February, after three times at the track and 4 at a strip and light driving around.
I also noticed that the pins on the other side are lose!!!!
I was thinking of letting the new pad resurface the rotor.
Right before it blew up at Laguna Seca last November 30thBlack 97 854R, Sport Grill, Urethane Top Bushing, Momo Strut brace, Koni shocks, K&N air filter, B&M Tranny cooler, Upsolute ECU, Accel super coil, Magnacore plug wires, Custom Swedish I/C, Reverse I/C piping W/Samco hoses, HKS SSQV BOV, Polished Throttle body, Custom 3" S.S. down pipe, Magnaflow 3" Catalytic, Apexi 3" Muffler, IPD Sport Springs, IPD Sway Bars, QuickBrick Motorsports end links, Brembo Lotus calipers & 320x28mm X-drilled front rotors with Brembo Galpher pads, Brembo X-drilled rear rotors with EST Carbon Fiber pads, Stainless Steel brake lines, 215x45 17" Toyo Proxes 4 on Volans, 235/40 17" Toyo RA1 on Team Dynamics Pro-Race 1.2 17"x8" (for track), IPD Skid plate, Greddy TT, Custom 3 guage pod, AEM WB o2, Auto Meter Z-series Boost, EGT, Oil press, Water temp., Tranny temp. gauges, Mobil 1 w10/30, Royal Purple ATF, Horns moved for air flow, de-badged,
