Slevin
M58 clutch
Hi,
I have an 07 V70 2.5T AWD and my clutch has started to slip after a tune and exhaust upgrade.Previous owner says the clutch was replaced in 2018...anyway is there a stronger OEM clutch that would fit without changing the DMF, too? What could be the difference between the clutch for an M66 2.4 T5  and my M58 AWD'S clutch?
The 07 M58 has the same 23 spline input shaft as the M66. You should be able to use a S60R/V70R clutch kit which should be rated for higher torque than the clutch you have.
Yes, that's what I was thinking, but I've been told the m66 clutch would not fit...
7 hours ago, Ihatespeedbumps said:
Moving to performance for move viability.
Thanks.
