98s70t5mvt
P80 p2 parts etm turbo downpipe turbine housing injectors
Bought an 04 c70 b5234t9 to swap
Have
Fuel rail with blues $30
ETM with intake manifold $80
Auto flex plate $30
P80
Sas pump $50
850 x70 air box $50
Exhaust manifold $20
New obx straight flange downpipe $200
Straight flange housing $55 (no cracks)
Stock straight flange downpipe with cat $100
Used td04hl-16t p80 feed ports, little to no shaft play $100
Low mileage (60k) td04hl-16t p2 style feed , no shaft play $200
Snail turbo cnc billet wastegate actuator fits straight and angle flange with 1 bar spring brand new valued $140 will sell $80..
Snail turbo - Td04hl-22t billet 6+6 (td05-18g) wheel extended tip 50mmx71mm with 9 blade turbine. Silicone hd cbv with medium spring 14-18psi
Has 4 open coolant port with plugs
Paid $960 was dropped by a friend and seems have some rubbing when spun by hand. Never installed so essentially new Will sell for $400 fp offers rebuild for $275. My loss is your gain. Good for around 320-360whp depending on boost and fuel.. Possible it's fine but had 2 so went with the other...
Edited by 98s70t5mvt
  • Similar Content
    • By JPittVolvo
      So i have been dealing with the oil cooler lines on my 1998 V70 Awd Turbo for a while. Vehicle has 169,000 miles or so on it now and since i have gotten the car i have put two sets of oil cooler lines on it. I have used the OEM lines each time with new seals etc. Well the second set is now leaking again from the connection at the rubber hose to metal clamping as the usually seem to start leaking at. I dont want to have to do a third set of lines or have these ones rebuilt. I was able to get a hold of the NA motor oil cooler block off plate that it uses instead of having oil coolers. Does anyone know if that would cause a big problem if i decided to put that on instead of new lines? The car is daily driven to work and back about 2 miles on local roads. Never take it on the highway etc, we use the wifes newer mini van for that. I am just worried that iuf i do the block off that the oil might be too high a temperature and burn out the turbo etc. Any thoughts would be greatly appreciated?
    • By mynewvolvoexp
      Hello everyone,
    • By greenellie
      Hey all! I'm planning on swapping in 'white' 350cc injectors, a 16T, and a '98 T5 ECU in my 1998 V70 GLT.
      Only issue is, I'm having serious trouble finding a T5 ECU! I need an automatic one...
      I've scoured Ebay and various other sites and they all seem to be non-turbo ECUs. I've found R and T5 upgrades online and they're all relatively expensive (150-200 bucks).
      Any help or advice would be greatly appreciated.
      Thanks,
      -Ellie
    • By justanotherhumanoid
      Looking for a TD04HL-16T or TD04HL-18T turbocharger such as the 16T found on 2001-2004 (maybe up to 2005?) Volvo S60 T5 vehicles (for the 16T) or 1999 V70R vehicles (for the 18T).
      Will replace a TD04L-14T which I believe has both coolant ports on the back.
      San Diego area would be ideal, will pay for a rebuilt one shipped if good rep.
    • By rcgomes
      hello, i buy a 2001 97k klm s60 t5. im reparing the car now, change the belt, plugs, etcetc. Im planing to know now "for save coin" the mods to make after the basic things done. i search rica and BSR flashtune but this is good only for stock turbo after change the turbo is useless. So what you guys experts thing about for mod the car for power widout open engine to upgrade rods etc? i search if i install a k24 turbo (hight spin turbo) this will put the torque enter sooner and maby will bend rods... and if lets say i upgrade for a t3tt4 50 trim turbo gt35?? maby will spin only after 3000k and dont put stress in botton end?
      can help please? i plan to mod car for around 350/380 hp
      first thing KN filter, snabb bigger intercooler and pipes, Downpipe. thank you for help...
      now the car is stoped because have all parts atock, so plugs, belt, gas filter, and all oils for now. thanks
      skf good brand for belt kit and pump? and mahle gas filter?oem plugs.  thank you
