Turning Rotors
9 replies to this topic
#1 merlin390
merlin390
  • 2,778 posts
Posted 03 May 2005 - 09:42 PM
Anyone out there that can tell me how Volvo says to turn the rotors on a '96 854?
on the car or off the car?
#2 ToxicLemonade
ToxicLemonade
  • 2,595 posts
Posted 03 May 2005 - 09:45 PM
i think the only way you can turn any rotor is off the car.
Yellow 5 speed T5-R
#3 MrWinkey
MrWinkey
    Am I drunk? You tell me!
  • 4,759 posts
Posted 03 May 2005 - 11:12 PM
They are turned off the car...only non seperable hubs (like Honda) get turned on car...I will tell ya' I have had no sucess with turning the composite rotors
"SMOKE TROUT NOT CRACK"
#4 theunderlord
theunderlord
  • PipPipPipPipPipPip
  • 14,738 posts
Posted 03 May 2005 - 11:13 PM
QUOTE(MrWinkey @ May 3 2005, 04:12 PM)
you any good at machining? (serious question, not meant as jerkiness)
#5 MrWinkey
MrWinkey
  • 4,759 posts
Posted 03 May 2005 - 11:21 PM
QUOTE('98S70R @ May 3 2005, 07:13 PM)
Have I run a CNC lathe...no...but I have turned a few rotors in my day...what I meant by that is if your turning rotors usually it's due to warpage. And with the Volvo rotors 23mm is min if you get anywhere close to that after machining you may as well replace them because your warpage will return...not to mention I hate slow cuts waste of time and money. My opinion only
#6 Tom
Tom
  • 185 posts
Posted 03 May 2005 - 11:29 PM
QUOTE(MrWinkey @ May 3 2005, 06:21 PM)
My opinion as well. Turning Volvo rotors is a losing proposition.
'94 850 wagon, N/A, automatic, 170K.
#7 merlin390
merlin390
  • 2,778 posts
Posted 03 May 2005 - 11:57 PM
I dont like turning rotors either but I know these have never been cut. I would rather replace them but right now $$ is in short supply. I have access to a brake lathe and I know how to use it biggrin.gif so If i can get them to last 6 more months all will be good. I am going to pull the tires and measure the rotors tomorrow night and probably cut them. the front min is 23mm, whats the min on the rears? ('96 854)
#8 MrWinkey
MrWinkey
  • 4,759 posts
Posted 04 May 2005 - 12:02 AM
I wouldn't cut them unless you have a vibration issue?....rears are 7.5 or 8mm I think not real sure off the top of my head..the min. spec is stamped on the rotor
#9 merlin390
merlin390
  • 2,778 posts
Posted 04 May 2005 - 12:08 AM
oh yeah it has vibration. I am going to use the dial guage and measure my runout on all four rotors, I am pretty sure all 4 will need machining. Last time I changed my oil I rotated the tires and checked the pads, there is plenty of material on them so I will brake the glaze with some sand paper and rebed them after machining. Heck might as well buy some DOT4+ and flush my brake lines
#10 KLS
KLS
  • 727 posts
Posted 04 May 2005 - 06:25 PM
Hunter's on-car brake lathe
http://www.hunter.com/pub/product/lathe/5071T/index.htm
If you have access to a dial indicator, index the rotor when you reinstall it on the car. Try different positions to find the position with the least runout. Even if you machine it true, differences on the hub and how it fits the hub can cause enough final runout to cause brake pulsation.
Ken
Edited by KLS, 04 May 2005 - 06:28 PM.
