Misfires & Oil Leak
6 replies to this topic
#1 Nebor
Nebor
    TEAM BRAKE LUNCH
  • 3,472 posts
Posted 03 May 2005 - 11:26 PM
I changed my rear O2 sensor last night, to remedy my P0422 code. Success. But then, a little while ago, the check engine light returned. P0300, P0301, P0304 and P0305. Cylinder misfires. Before I could clear the codes however, they cleared themselves. So I'm not sure if I should even worry about that...
While changing the O2 sensor, I noticed that the bottom of my oil pan was covered with oil, which seemed to be coming from the front of the engine. When I say front, I mean the side closest to the car. Any ideas on this?
#2 MrWinkey
MrWinkey
    Am I drunk? You tell me!
  • 4,759 posts
Posted 03 May 2005 - 11:29 PM
???? not sure what your saying...possibly dipstick tube o-ring?
"SMOKE TROUT NOT CRACK"
#3 jens94850
jens94850
  • 175 posts
Posted 03 May 2005 - 11:34 PM
QUOTE(Nebor @ May 3 2005, 07:26 PM)
Side closest to car=passenger side, or closest to front of car? In first case, the problem is probably front engine seal (behind crank pulley) or one of the cam seals above. If second case, check tranny lines at radiator and check that dipstick tube is firmly in place as it enters the engine. Is car a turbo?
Jens Christensen
#4 orange850t
orange850t
  • 868 posts
Posted 03 May 2005 - 11:40 PM
If it's a turbo (your sigy doesn't say) I would guess it's the return line seal.
95 855T Autumn Gold
#5 Nebor
Nebor
    TEAM BRAKE LUNCH
  • 3,472 posts
Posted 03 May 2005 - 11:59 PM
Sorry, I meant the front of the car, which would be the side of the engine. I'd guess the leak is coming from somewhere under the intake manifold.
When I bought the car and had it inspected, they said the replace the return line gaskets, and I have the parts to do it, but I inspected the return line and surrounding area myself, and it's bone dry.
So yeah, the bottom of the oil pan is covered with oil, that seems to be coming from the front of the car.
#6 Nebor
Nebor
    TEAM BRAKE LUNCH
  • 3,472 posts
Posted 04 May 2005 - 03:20 AM
I had the transmission fluid flushed at a regular (nonvolvo) type shop. Is it possible that they didn't replace the necessary seals or clips when putting the lines back on, and that this is ATF?
#7 kenhoeve
kenhoeve
  • 2,617 posts
Posted 04 May 2005 - 05:04 AM
well, black is oil. red would be ATF.
you need to degrease the pan and engine. then run it and get under there and see if you can spot the source.
2007 V70R
