Cv Boots
4 replies to this topic
#1 yangotang
yangotang
    yangbang!
  • 6,634 posts
Posted 04 May 2005 - 06:24 AM
My CV Boots are leaking grease, and I wholehearedly intend to remove and replace the CV Boot instead of installing a new axle.
Two Questions:
The CV Boots which are leaking are the ones which are closer to the subframe. One is adjacent to the Front Engine Mount, while the other is adjacent to the tranny. Are these the 'inner' or 'outer' CV boots?
FCPGroton sells a kit for the CV boots. However, I would rather pick up a boot from a store locally. Based upon conjecture and some observation it seems as if the CV boots are very similar, no matter where they are purchased. Are there any differences in construction which I should be aware about if I were to buy from, say, NAPA Auto Parts? The parts from various suppliers seem astoundingly similar.
Thanks in advance!
EDIT: Sorry, I posted this in Performance Modifications. Can a moderator please move this thread to FWD/AWD Maintenance, where it belongs? Thanks!
Edited by yangotang, 04 May 2005 - 06:26 AM.
Alex
#2 thelostartof
thelostartof
  • 1,853 posts
Posted 04 May 2005 - 07:47 AM
if you do plan to go w/ a parts store brand .. PLEASE test them out as in take them out of the box and feel them up GOOD. as you can tell right away if its a high quality part or something that might tear uber easy
#3 jwmerrill
jwmerrill
  • 629 posts
Posted 04 May 2005 - 10:09 AM
QUOTE(yangotang @ May 4 2005, 02:24 AM)
I believe these would be the inner boots. The outer boots would be the ones that cover the CV joint right behind the wheels.
jwm
1999 C70 HPT 5 speed, Upsolute ECU Upgrade, 19T Turbo, Supersprint Exhaust, 3" EST Downpipe, EST Intercooler, S60R Exhaust Manifold, Clear Corners and Euro Clear Headlights, BMC CDA Intake, OEM Strut Brace, XC70 Grille, IPD Sway Bars F/R, KW Variant 2 Coilovers, VMS sway bar links, Aluminum Dash OEM and EST Short Shifter, HRE 446Rs w/ Goodyear Eagle F1 GS-D3s Defi D-Gauge boost gauge, Innovate WBO2, HTS hoses, Samco stuff. - VMS Motor installed
1998 C70 HPT 5 speed saffron metallic, 61,000 miles,
IPD Sway Bars F/R, KW Variant 2 Coilovers (***Not installed - Clear Corners and Euro Clear Headlights, OEM Strut Brace, XC70 Grille***)- ***SOLD***
2001 XC70 White - Wife driven
Past Volvos
1998 S70 T5, black - My first Volvo
1996 850
1998 C70 auto, white
2005 XC90 - Disappointing POS
#4 Guest_AlvinL_*
Guest_AlvinL_*
Posted 04 May 2005 - 11:52 AM
I don't know about aftermarket ones but the dealer sells the kit that includes the inner and outer boots; 2 types of grease for inner and outer boot; clamps and 2 types of axle nuts.
#5 Che'_Moderator
Che'_Moderator
    Monkey Master
  • Admin
  • 24,209 posts
Posted 04 May 2005 - 02:35 PM
QUOTE(AlvinL @ May 4 2005, 05:52 AM)
If its the smaller of the two its the inner. I use aftermarket ones on my car all the time with 0 problems so far.
