Replacing Heater Core
13 replies to this topic
#1 bocavolvo
bocavolvo
  • 39 posts
Posted 04 May 2005 - 09:26 PM
Im going to replace my heater core on my 99 s70 this weekend. I looked over the thread on the forum explaining the replacement and it looks fairly simple. Has any one else had to replace their heater core and if so any suggestions.
#2 jp1733
jp1733
  • 84 posts
Posted 04 May 2005 - 09:36 PM
when you put trash bags down so it doesn't leak onto your carpet, you should tape your trash bags up so the fluid pools instead of running all over the trash bag. i also put trash bags under the bag that i had the fluid run on.
hope this helps
john
1996 Volvo 850 2.3L Turbo Black
Volans w/eagle F1's
ipd strut bar
Koni sport shocks/struts w/TME springs
#3 bocavolvo
bocavolvo
  • 39 posts
Posted 04 May 2005 - 09:38 PM
Thanks for the tip. Was the whole procedure pretty simple.
#4 MrWinkey
MrWinkey
    Am I drunk? You tell me!
  • 4,759 posts
Posted 04 May 2005 - 11:13 PM
Really you have a bad core in a 99 s-70? Are you sure...just asking cause thats a fair amount of work
"SMOKE TROUT NOT CRACK"
#5 bocavolvo
bocavolvo
  • 39 posts
Posted 05 May 2005 - 05:35 AM
yeah. I have a continuous loss of coolant and all the typical bad heater core signs. Coolant smell coming from vents, foggy windshield. But i think it was the steady flow of coolant dripping out of the heater core box that really gave it away. The dealership wanted something around $500 for the repair but the thread about replacing the heater core made it seem to be pretty do able for a decent do it yourselfer.
Edited by bocavolvo, 05 May 2005 - 05:52 AM.
#6 Guest_Guest_*
Guest_Guest_*
Posted 05 May 2005 - 04:24 PM
I removed the heater hoses before removing my core, to keep the spillage to a minimum.
Have another suggestion, if you have an air compressor, take an air jet, and put the jet in one of the holes where the hoses run into the core piping at the fire wall, take a container to catch the anti-freeze and hold it under the other hole, and blow compressed air into one hole. This should force most of the anti-freeze out of the core, and prevent much spillage. Just go easy with the air.
The remainder of the repair, is a straightforward un-bolt, bolt swap. Remove the A/C drain line, just behind the core housing, to make removal and reinstall easy too.
BB
#7 98V70BASEBOY
98V70BASEBOY
  • 194 posts
Posted 05 May 2005 - 04:26 PM
BB
1998 V70 N/A
Stock except for custom treatment on center console.
151,658 miles as of 11/24/2008
#8 jp1733
jp1733
  • 84 posts
Posted 05 May 2005 - 04:51 PM
air is a great idea!...just don't keep to air-happy like he said.
Volans w/eagle F1's
ipd strut bar
#9 bocavolvo
bocavolvo
  • 39 posts
Posted 05 May 2005 - 06:57 PM
thanks for the tips guys. Unfortunately i dont have an air compressor so it may get a little messy while removing the core. Thanks for the tips though. By the way is it difficult getting to the bottom screws on the heater core box, and did you guys replace the o rings as well.
Edited by bocavolvo, 05 May 2005 - 06:59 PM.
#10 98V70BASEBOY
98V70BASEBOY
  • 194 posts
Posted 06 May 2005 - 12:45 AM
QUOTE(bocavolvo @ May 5 2005, 01:57 PM)
The bottom screws are removed once you have the core and the bottom part of the housing out (They come out together.) Remove the screws joining the top and bottom halves of the housing, and one screw that holds the piping to the bottom of the core, and pull down and toward the console.
New o-rings
If no compressor, you could try a length of tubing and try forcing it out with your breath. Be VERY careful with this though. Probably easier just to use the plastic bags to good effect. biggrin.gif
1998 V70 N/A
#11 bocavolvo
bocavolvo
  • 39 posts
Posted 07 May 2005 - 05:25 AM
thanks for the tips baseboy. Now I just need my parts to hurry up and get here so i can let the fun begin
#12 Guest_Guest_*
Guest_Guest_*
Posted 08 May 2005 - 05:37 AM
When i did my core with the pictures present on the write up, i had about 6 oz's of fluid come out. (just shy of a full 8 oz styrofoam coffee cup) It was negligable.
Also helps to have the car parked on level ground.
#13 Modus
Modus
  • 693 posts
sorry that was me^^^^^^^^^^^^
#14 classiguy3
classiguy3
  • 19 posts
Posted 08 May 2005 - 05:16 PM
1 questions, can the heater core be repaired by a radiator shop?
