I am looking to replace the spring seats on my 94 850 NA 5-speed. When viewing the top of the struts from the engine bay there is a space between the nut and rubber peices. From reading on here i have deducted that this cause by broken spring seats. The car clunks when going over bumps. Also has 172k on stock set up.
I could Find spring seats on fcp only found Strut mount bushing are theses the same
part # L3031-104479
Can i resure the nut, washer and all the other piece on the top of the strut. Where can i get new one the dealer.
I am on a budget and just want to prolong the life of the car a touch. What happens if i don't replace them??
Spring Seat/strut Mount Bushing
Started by 744Ti, May 04 2005 10:55 PM
7 replies to this topic
Posted 04 May 2005 - 10:55 PM
98 s70 5 spd, 166k working on stage 0
91 944Ti getrag Swap, 6-puck disc, block distributer conversion, K cam
Header & exhaust in progresss
Posted 04 May 2005 - 11:02 PM
You just need the spring seat about $30/$40 you can reuse the nuts
"SMOKE TROUT NOT CRACK"
Posted 05 May 2005 - 04:20 AM
Could someone please varify this part on from FCP. FCP does not list a spring seat (or at least i could find one) but i belive that this is the correct part
http://www.foreigncarpartsonline.com/
part # L3031-104479
thanks
part # L3031-104479
thanks
Posted 05 May 2005 - 04:25 AM
QUOTE(744Ti @ May 4 2005, 10:20 PM)
part # L3031-104479
thanks
part # L3031-104479
thanks
Here this may help:
Volvospeed On Google+
Posted 05 May 2005 - 01:56 PM
Thanks. That confrims what i though. I need to get a new strut mount bearing. It seems that it is often called the spring seat on this board.
thanks for the clarificaiton
Posted 05 May 2005 - 05:26 PM
QUOTE(744Ti @ May 5 2005, 07:56 AM)
It actually is the spring seat but as long as you ordered a part that looked like that your fine.
Posted 05 May 2005 - 11:17 PM
FCP calls it the strut mount bushing
Posted 05 May 2005 - 11:54 PM
Guys the nice drawing is mis-labeled.
