RobT5M
Static on P80
Morning guys,
Hoping someone has had or dealt with this issue that can possibly help.
Almost since ive had the S70 (98) I've always had static with the headlights on, when you turn them off, the static goes away.
Same with if I turn on the rear window defrost, if its on, its static on some channels and goes away once off.
Looking for some suggestions on possible causes and things to chase down to remedy this situation.
either some wires are crossed somewhere or it's a ground somewhere.
Whelp this should be fun to try and find lol.
Im guessing it would be a body ground near the antenna?
I need to pull some carpet out to upgrade the wiring to the fuel pump so mineaswell pull a bit more and check that while im in there.
being that it happens when something is turned on, makes me think its a crossed wire.
You know what... Now that you say that, im wondering, ive never gone over the wireharness im using for the aftermarket radio, still using the same one billy had in the car when I bought it like a decade ago.
Guess its time to look into that.
