Shifting Gears
5 replies to this topic
#1 Guest_Brickwagon_*
Guest_Brickwagon_*
Posted 05 May 2005 - 01:33 PM
huh.gif In the 1994 Volvo 850 sedan, is the light bulb for the center console shifter the same as the ashtray light???
Thanx!!!
#2 MrWinkey
MrWinkey
    Am I drunk? You tell me!
  • 4,759 posts
Posted 05 May 2005 - 11:25 PM
Possibly...never replaced the ashtray bulb...the shifter bulb is a prindle bulb
"SMOKE TROUT NOT CRACK"
#3 Bay13
Bay13
  • 6,378 posts
Posted 05 May 2005 - 11:45 PM
Two different bulbs.
#4 Bay13
Bay13
  • 6,378 posts
Posted 05 May 2005 - 11:50 PM
OK just checked with parts and they are the same bulb Volvo part number 1363149
#5 Guest_Brickwagon_*
Guest_Brickwagon_*
Posted 06 May 2005 - 11:46 AM
biggrin.gif Thanx for the response!!!!
The center console is up/out, and I could not see any bulb receptacle for the shifter, EXCEPT for the one connected to cigarette lighter/coin holder module. It is attached to the side of the cigarette lighter.
I removed the bulb, and it was identical to the one that I just purchased from the dealer for $9+ with tax blink.gif and inserted/locked the bulb into the black, plastic clip/holder.
Today or tomorrow, I will attempt to reinsert the clip into the square, oblong metal container attached which, I think, holds the black plastic receptacle for the bulb.
There seems to be an element of difficulty, because when I removed cigarette lighter and ashtray modules, the light clip with bulb had fallen out of the metal container. You can tell someone has been there before.
I will also call the dealer for light bulb part number.
#6 Guest_Brickwagon_*
Guest_Brickwagon_*
Posted 06 May 2005 - 11:02 PM
laugh.gif They are both the same!!!
Two bulbs, same number: one for cigarette lighter and other to light up the shifter gears.
I bought the two bulbs today and replaced them. There is a separate holder for each. Bay 13 does have a detailed printout from a Volvo member for the S70, and it does say that it can apply to an 850.
Also, the dealer printed out the parts drawing (A picture is worth a thousand words).
