BEST TURBO 350HP IN 2.4T?
FURIA T5-R
Hello, greetings, I write from Spain because cars are hardly modified here, I have read quite a few threads about what turbo to exchange and most of them are quite old, I imagine that for 10 or 15 years the thinking about the most modern lpt engines has changed . Currently I am running a RICA stage with a t16 and panel filter, the car has improved a lot compared to the stock, but logically I need more, especially in the high zone, I feel that the car is drowning above 5,500 rpm, I have been thinking on the k24 exchange but i have read some reliability issues and it also has an early reel. At this moment thanks to some threads in this forum I have seen some kinugawa turbos that could help with the high end, but I also heard that some are restrictive at high rev, could you indicate the best model according to your experiences or knowledge for a good top end and A power that is around 350 hp on the steering wheel, I have some blue injectors model 99 t5 with its regulator, it would not be a problem to make modifications to the downpipe or water and oil lines, a greeting and thank you very much
  • 2 weeks later...
I will try to change the thread of the topic due to the great success, after all the years of experience in this forum, what turbo would you recommend for a 2003 b5244t3 block, I understand that they improved a lot with respect to the old lpt, I know that they are not yet a 2.3 hpt, but I would like to know in 2020 what is the consensus on maximum power in a stock lpt vvt engine block, and which turbo would work best to achieve that power goal, I know that td04hl have early boost and high egt, and k24 cracking problems, so you guys just show me the way to go, maybe I should go with a bigger turbo with less boost? some example? thanks
  • 3 weeks later...
