Manual conversion help needed urgently
I've done the manual swap on my 01 S60 with m56. I had to get a retune to accept the manual. I also had to:
  • Short green/red and green wires on Gear Position Sensor together
  • Remove TCU, connect green & white wires to matching-color counterparts
  • Yellow, Blue, Yellow/black wires on Gear Position Sensor grounded (this one took a long time to figure out - no-start condition)
  • Relay for starter re-wired to ground to chassis (rather than look for Central Engine Module ground signal) (this also took a while to figure out - no-start condition)
Nothing I did matched the symptoms you have. I suspect it's your ECU needs to be reprogrammed.
