Our mechanic says that a strut is bad on the 1995 850 GLT (there is an intermitent clunking/rattle) and that the bushing should be replaced at the same time. Is this true and how serious is either part, if becoming defective. Thanks.
1995 850 Glt Struts And Bushings
Started by
Guest_Guest_archtop_*_*
, May 05 2005 11:51 PM
5 replies to this topic
#1 Guest_Guest_archtop_*_*
Posted 05 May 2005 - 11:51 PM
Posted 05 May 2005 - 11:53 PM
If you are putting in new struts, yes new top strut mounts are needed.
#3 Guest_Guest_*
Posted 09 May 2005 - 11:49 PM
It's probably just the rubber spring perch making the noise..as for the struts needing replaced?
"SMOKE TROUT NOT CRACK"
Posted 09 May 2005 - 11:51 PM
Hard to tell, once the strut is out, if it collapses easily then yes replace them. Mileage also has a play in replacing or not. If the top strut bushing/mount wasnt broken you could bounce the car and see how it responds to determine if you will need new struts.
Posted 10 May 2005 - 03:26 AM
I'd say if you have over 100k miles on the car, it's time for new shocks
96 855R 158k miles
