For Sale 1995 Volvo 850 T5R. I’ve had this car since 1998. Previous owner was a Volvo Mechanic. Always used Mobile 1 full synthetic oil. This car can run on E85 or Gasoline. Interior is near perfect. Color is black under orange plastidip (which can be removed). 174,000 original miles. About 400 crank HP. Could use drag radial tires to help with traction! Heat works! A/C works! Can be bypassed with a shorter belt which is included. $7,000
Carbonfiber hood
Black Coated Front Grill
Carbon Fiber Volvo Emblem
Euro Turn Signals
Rear spoiler from 96+ 850R has a big lip.
Custom Leather Driver Seat
Engine / Trans:
19T turbo (Max boost on E85 21psi, 15psi on gasoline)
Volvo S60R exhaust manifold
Forge Bipass Valve
Kinugawa Wastegate
Front Mount Intercooler with piping
Volvo N/A Cams (hotter than stock turbo cams)
3” Turbo Back Exhaust
D200 Fuel Pump
800cc fuel injectors
Custom tune able ECU with many boost maps (uses a common tuning software called Tuner Pro) 5 seconds to switch from gas to E85, turns check engine light into a knock sensor light.
Unorthosdox racing under drive pulley
Volvo N/A intake manifold (to fit larger throttle body)
Volvo N/A throttle body with better throttle plate
Volvo V90 MAF (flows more than 850 turbo MAF)
Hard intake pipe with AEM dry filter.
Coil on plug setup (uses stock 1999+ Volvo V70R Coil Packs )
5 speed transmission with Gripper Limited Slip Differential Installed.
Suspension:
Eibach Progressive Lowering Springs with Heavy Duty upper spring mounts.
Bilstin HD Yellow Struts
IPD Anti-Sway Bars
IPD Heavy Duty Sway bar End-links
OPB Strut Brace
Polyurethane Sub-frame bushings
Aluminum Control Arms
XC90 Sub frame Brackets
Derlin Firewall Engine Stabilizer Bushing
Wheels:
Black with orange TDR 17X8.5 wheels, with 235/40/17 All season Z rated tires (Fairly New)
Comes with extra wheel and tire for a matching spare!
Brakes:
Brembo 4 piston calipers all the way around, professionally hand painted with R logo stickers
330mm Stoptek Drilled Rotors (Stock size is 280mm)
Other:
HKS Turbo Timer with voltage gauge
Digital Boost gauge with peak hold
Knock sensor Light
Wideban O2 Guage
Magnetic Drain Plug
Volvo S70 Oil Pan (Better then 850 pan)
Edited by Boost Addicted
Get some photos of the interior up!
I vaguely remember this car.
Gary - fwiw looks like colorado plates
Wow I almost feel like its under priced.
Good luck with the sale, post it on facebook, with the current value of these stock it shouldnt last long at all.
