Air Pump, Relay And Sas-valve Changed. What Next?
Started by johan_modig, May 06 2005 11:40 PM
13 replies to this topic
Posted 06 May 2005 - 11:40 PM
Hi,
I have a 1996 non turbo and have just replaced the air pump (filled with water), pump relay (dead), and SAS valve (full of black gunk).
Still no go. Pump does not run on cold start and I don't have vacuum at the SAS-valve (the purple line).
Is there a fuse for the system that may have burned or should I go through electrical connections?
Any pointers/suggestions most welcome since I have emissions test coming up and I need to get rid of the CEL.
TIA
/Johan
TIA
/Johan
1996 855 2.5 10v NA manual
Few horses and lotsa miles
Posted 06 May 2005 - 11:48 PM
Did you clear the codes and drive the car...if you just put the stuff on and expect the light to go out it doesn't happen that way...the main thing with the emission test is getting the monitors up which requires a drive cycle after replacement of parts and clearing codes and your year car the drive cycle can be a real bear to hit right sometimes
"SMOKE TROUT NOT CRACK"
Posted 07 May 2005 - 12:47 AM
The large yellow arrow points to where the controller is at, that is where the other end of the purple vacuum line thats on the SAS valve attaches to. You really need someone with a Volvo scan tool so they can activate the system and see whats not working.
#4 Guest_Guest_*
Posted 07 May 2005 - 08:48 AM
Thanks for the input from both of you. Looks like I'll just have to bite the bullet and take the car in to the dealer.
Cheers
Johan
Cheers
Johan
Posted 07 May 2005 - 04:26 PM
Some independent shops have the volvo scan tool and know how to use it as well.
Posted 07 May 2005 - 05:00 PM
Thanks for pointing this out. I'll check with a couple of local shops on Monday.
MRWinkey: is the "drive cycle" you refer to the same as outlined in this dodument http://ebv.mimnet.northwestern.edu/~aiyar/..._Inspection.pdf?
Cheers
/Johan
Cheers
/Johan
Edited by johan_modig, 07 May 2005 - 05:38 PM.
Posted 07 May 2005 - 05:39 PM
Yes to your link that is a nice example of what a drive cycle is.
Posted 09 May 2005 - 06:13 PM
Follow up:
Took the car in today and got my codes read to the tune of $37. After resetting all codes it turns out "EFI-521" comes back which means I've got a dead front O2 sensor.
Anything special to consider before I go ahead and shell out the cash for a new one and go about changing it apart from the excellent info on http://volvospeed.com/Repair/o2sensor1.php?
Cheers
Johan
Cheers
Johan
Edited by johan_modig, 09 May 2005 - 06:24 PM.
Posted 10 May 2005 - 12:08 AM
Nope ..just replace the front 0/2 chances are the rear 0/2 won't be far behind on failure....now wasn't that $37 worth it?
Posted 10 May 2005 - 12:13 AM
good for 1996 to 1998 plus the convertables to the present for the tops.
Posted 10 May 2005 - 12:32 AM
Yeah I know..I use a Snap-on generic obdII but I have an AST for the real issues..98 it's maxed out..lookin into a Baum new on the market..but with the VST I could see things that the AST won't tell me, I could also induce readiness monitors which the AST won't do
Crazy technolgy will bring death to us all someday? Winkey Rogers in the 21st1/2 century
Posted 10 May 2005 - 07:28 AM
QUOTE(MrWinkey @ May 10 2005, 12:08 AM)
It sure was. I will report back how things work out.
/Johan
#14
Posted 10 May 2005 - 06:38 PM
Replacing O2 sensor wa a breeze and initial tests indicate that CEL is finally gone. Haven't driven very far though so maybe it's too soon for the final verdict.
cheers
/Johan
cheers
/Johan
