Stripped The 10mm Bolt
25 replies to this topic
#1 pete0r
pete0r
  • 435 posts
Posted 08 May 2005 - 02:25 AM
hey guys,
i finally got under my car to fix the leaking oil issue. once i got a light under there, using bay 13's directions, i figured out what to do, but the 10mm bolt that i need to remove was pretty stripped. it isn't toally stripped, but it's pretty bad. i was mad that i couldn't fix it.. are there any good tips or tools to use to remove it? hopefully something cheap?
on a side note, the area where the return line comes out (in to?) the engine block was totally covered in some sort of silicone, i guess someone once tried to stop the leak that way.. heh.
thanks!
1995 855 Turbo - 190k Miles
#2 mykidsarebrats123
mykidsarebrats123
  • 37 posts
Posted 08 May 2005 - 02:50 AM
QUOTE(pete0r @ May 7 2005, 07:25 PM)
hey guys,
thanks!
go to sears hardware there are easy outs, or bolt extractors I forget what they are called but they work awesome.
95 Volvo 850 T5 Wagon Blk/Tan SOLD
2001 Ford Excursion LTD 7.3 Powerstroke Grn/Tan
1993 Ford Taurus SHO Wht/Blk
#3 prasamin
prasamin
    Bipedal Magnaflux
  • 16,242 posts
Posted 08 May 2005 - 02:54 AM
bolt taps?
oh, I need to do the return line fix....was it easy to access?...obviously you didn't get to it, but when you got under the car (which I haven't done yet in regards to the return line) did it look pretty easy to access?
Edited by prasamin, 08 May 2005 - 02:55 AM.
#4 JHEIII874T5M
JHEIII874T5M
    Level 6 Senior Member
  • 14,845 posts
Posted 08 May 2005 - 12:52 PM
what we did was took a dremel and just cut 2 notches into it, i.e. to just use a flathead screwdriver and take it out. Then take it to lowe's or a bolt specialty store and they'll have it for you to replace.
Joseph H. Essaye III
#5 pete0r
pete0r
  • 435 posts
Posted 08 May 2005 - 01:39 PM
QUOTE(prasamin @ May 7 2005, 10:54 PM)
bolt taps?
it was alright.. i still had issues with getting the wrench in there but if the bolt wasn't stripped. it would be possible
#6 turbobrick
turbobrick
  • 2,728 posts
Posted 08 May 2005 - 01:59 PM
i thought those bolts were allen head ? usually you can tap a larger size wrench in, what i've done in the past if its been so stripped.
Edited by turbobrick, 08 May 2005 - 01:59 PM.
"i can read most any drivers moves and react accordingly. plus its halrious when they're maxed out and u draft by them like a cakewalk." - HTownTurbobrick
Chris | 95 850 Turbo | ITS SLOW
#7 Guest_Guest_*
Guest_Guest_*
Posted 08 May 2005 - 05:07 PM
QUOTE(prasamin @ May 8 2005, 02:54 AM)
bolt taps?
This was one of the easiest fixes i've done to the volvo. It takes about 15 minutes, unless you run into a problem like peter0r. Bay13's instructions make it real simple.
#8 prasamin
prasamin
    Bipedal Magnaflux
  • 16,242 posts
Posted 08 May 2005 - 05:24 PM
when you do this, does any oil leak out, or do you have to do an oil change afterwards?....I just assume when you disconnect the line, it would spill out oil?
#9 EricF
EricF
    tbricks spy
  • 4,163 posts
Posted 08 May 2005 - 05:27 PM
Have you tried some serious clamping down force with a pair of vice grips? If I can access the bolt, that's typically enough to get it out.
#10 beachnut
beachnut
  • 2,947 posts
Posted 08 May 2005 - 06:03 PM
Depending on which of the two bolts is stripped I think it'd be tough getting a pair of vice grips in there ... but maybe I'm wrong, try it anyway ... desperate times call for desperate measures wink.gif Accessibility is *okay*, but not great.
Pras - No oil will come out when you do this repair.
Edited by beachnut, 08 May 2005 - 06:04 PM.
- Scott
'05 S60 T5
'04 S80 2.5T
#11 prasamin
prasamin
    Bipedal Magnaflux
  • 16,242 posts
Posted 08 May 2005 - 10:02 PM
QUOTE(beachnut @ May 8 2005, 06:03 PM)
#12 xtonyx
xtonyx
  • 220 posts
Posted 08 May 2005 - 10:59 PM
i did the return line fix.
easy as cake.
#13 MrWinkey
MrWinkey
    Am I drunk? You tell me!
  • 4,759 posts
Posted 08 May 2005 - 11:13 PM
10mm...so I guess your talking about the bolt and nut that hold the two lines together. that's all it is a bolt and a nut...instead of a wrench try a 10mm 12 point socket and you need a wrench on the top as well...if its really rounded you may be able to get a 3/8"socket on it... if all else fails you could always cut the clamp down the middle and buy a new one
"SMOKE TROUT NOT CRACK"
#14 pete0r
pete0r
  • 435 posts
Posted 09 May 2005 - 04:21 AM
i went to sears and got these:
i'll try them tomorrow
#15 WhiteT5
WhiteT5
    Sampson
  • PipPipPipPip
  • 4,828 posts
Posted 09 May 2005 - 02:07 PM
QUOTE(pete0r @ May 7 2005, 08:25 PM)
thanks!
^^^ Like this? This is a pic from my car. Looks like two idiot mechanics in two different parts of the country had the same idiotic idea monkey.gif . Mine hasn't started leaking.... yet, but I do have an extra gasket and o-ring laying in the tool closet in case it does start leaking.
- Sean
#16 prasamin
prasamin
    Bipedal Magnaflux
  • 16,242 posts
Posted 09 May 2005 - 02:21 PM
that's just messed up man...
#17 pete0r
pete0r
  • 435 posts
Posted 09 May 2005 - 02:32 PM
QUOTE(White850T5 @ May 9 2005, 10:07 AM)
even worse then that, i'll try to get a pic today
#18 pete0r
pete0r
  • 435 posts
Posted 09 May 2005 - 09:09 PM
here's a photo of the leaking part and the stuff whoever put on it:
and here's the stupid bolt. i'm thinking of taking it into the volvo place or an indy place and just having them deal with it, it's becoming quite a pain.
#19 TorqueSteer
TorqueSteer
    Pretty Boy Racing
  • 4,231 posts
Posted 09 May 2005 - 09:42 PM
I have that whole peice sitting right here next to me, its been off for almost a year, you dont need that whole thing, just dremel it off and call it a day.
#20 beachnut
beachnut
  • 2,947 posts
Posted 09 May 2005 - 11:57 PM
^^^ agreed.
I thought you were talking about one of the two hex bolts on the turbo. Yeah, just hack that biatch off. You could probably pick that piece up real cheap from the dealer I'm sure if you feel better having it.
- Scott
'05 S60 T5
'04 S80 2.5T
