QUOTE(StickThatClutch @ May 8 2005, 12:50 PM)
Andrew,
I give the Fuzions are hard time. I'm used to a bit higher tires (S0-3 and Pilot Sports), so their grip doesn't impress me. The wet performance I don't think is all that great but I haven't had much chance to test it out (I hydroplane more but that's probably a result of me going from 205 to 225). I will say this though for the price they give you decent grip (better than re750s I've tried on other cars) and they don't seem to wear.
As for speed rating I would go for at least a V rating. Sure you may not go that fast but the tires do have different compounds for high speed ratings that are better for traction and resistance to heat transformation. That said all the tires I listed for your size would come in some sort of Z rating for about 100 a tire unmounted.
Good luck.
thanks for all your help Stephen!
i could get some of the S0-3 tires at Costco for a bit less than $180 each mounted and installed. i would go that way if i had wheels that i planned on keeping.
i'll check out the Fuzions, and make sure i go with something better than an H rated tire.
heh, the only problem is that i've been a pretty regular customer at the local Tire shop(a Tire Factory, i've even got an account there) but now i'm finding that they have a pretty limited selection. they do have Yokohama and Dunlop, but no Falken or Bridgestone.
