Vacuum Noise
#1 sp5368
sp5368
  • 686 posts
Posted 08 May 2005 - 08:53 PM
I can hear a hissing sound and I think it is coming from a vacuum check valve.Is this possible and If so where can I buy one. I did the hose up to the ear thing and when I put it near the check valve I can hear the air should I be able to hear that
#2 T5BRICK
T5BRICK
  • PipPipPipPip
  • 3,899 posts
Posted 08 May 2005 - 09:02 PM
QUOTE(sp5368 @ May 8 2005, 01:53 PM)
where is this vacuum check valve you are speaking of?
'06 Mazda3
#3 sp5368
sp5368
  • 686 posts
Posted 08 May 2005 - 09:24 PM
There are 2 and they both come off the same line off the intake manifold
#4 MrWinkey
MrWinkey
    Am I drunk? You tell me!
  • 4,759 posts
Posted 08 May 2005 - 11:20 PM
Mist carb cleaner around the suspected area and see if the idle changes
"SMOKE TROUT NOT CRACK"
