Sloppy Start
4 replies to this topic
#1 AJU
AJU
  • 163 posts
Posted 09 May 2005 - 01:16 AM
Ok, another one of those cold start questions. First thing in the morning, the car starts really slowly - cranks fine, but doesn't fire right up like usual. It acts almost like it is a little flooded. When it does start it is kind of a stumbling, weak start. Cranks fine.
I recently changed out the fuel pump (didn't change the relay) and didn't get it all sealed up again properly as I found out when fuel was spilling out of the assembly. I know I need to open it back up and either replace the gasket, plastic nut or both. I have been living with it by not filling up the tank completely for a while. I am sure that the tank is not sealed because when I unscrew the cap the sound of air rushing in is not there. But I don't smell gas.
This starting issue never occurs when the engine is warm. It almost never occurs after the first start of the day. My ideas:
leaky fuel injector(s)
bad fuel pump relay
gasoline vapor not being contained in EVAP canister
I have not yet pulled the plugs to see if one is more fouled than the others. Anyone have any ideas?
TIA
1996 855 N/A Manual
#2 shurgen
shurgen
  • 1,136 posts
Posted 10 May 2005 - 01:40 AM
Do a search here on Italian Tune-up
96 855R 158k miles
#3 AJU
AJU
  • 163 posts
Posted 10 May 2005 - 03:05 AM
QUOTE(shurgen @ May 9 2005, 09:40 PM)
I make sure to get plenty of revs in in my everyday drive
1996 855 N/A Manual
#4 starfish
starfish
  • 749 posts
Posted 10 May 2005 - 04:54 AM
Try cleaning your throttle body. Get an old tooth brush and some carb cleaner and scrub the carbon off the throttle plate and bore.
<insert witty comment here>
#5 AJU
AJU
  • 163 posts
Posted 10 May 2005 - 02:12 PM
QUOTE(starfish @ May 10 2005, 12:54 AM)
I don't think a dirty throttle body would have any effect on starting, as it is generally closed. I have cleaned out the IAC within the past couple of weeks, and I do keep it pretty clean.
1996 855 N/A Manual
