Wheel Bearings
#1 Sunhillow
Sunhillow
  • 1 posts
Posted 09 May 2005 - 01:42 PM
Greetings,
I have a 94 850. I just installed Bilstiens, IPD springs, roll and sway bars, axles and CV joints. I have a front end pulsing, as if the tire is off balance. Does anyone know what the wheel bearing feels like if they go bad?
By the way, upgrading the suspension is the best spent money I've put into the car!
#2 WhiteT5
WhiteT5
    Sampson
  • PipPipPipPip
  • 4,828 posts
Posted 09 May 2005 - 02:02 PM
Hhrrm, If I Recall Correctly, a bad wheel bearing usually gives a sort of whooshy grinding sort of sound. You may want to check clearance on all of the components, especially the new axle. One possible cause of the pulsing you speak of is a blown control arm bushing. On the '94, you can replace each bushing individually without having to replace the whole arm.
- Sean
#3 gatlin
gatlin
  • 141 posts
Posted 09 May 2005 - 04:19 PM
QUOTE(Sunhillow @ May 9 2005, 09:42 AM)
This describes well my experiences with failing bearing hubs.
http://volvospeed.com/Repair/FWDbearingHub.php
Gatlin
'98 S70 T5 - 223K miles
'04 XC90 T6 - 70K miles
#4 Gilhuly
Gilhuly
  • 1,506 posts
Posted 09 May 2005 - 08:54 PM
My wheel bearing made a sound like driving oveer the grooved pavement they do on the should of the road, just not as harsh. It is a dull roar that varies with speed.
