Wiring Aftermarket Fog Lights
8 replies to this topic
#1 turboV70
turboV70
  • 764 posts
Posted 09 May 2005 - 03:12 PM
I have aftermarket fog lights on my 98 V70 that are independantly wired. I have them connected to the battery and i just have a switch on my dash to turn them on and off. Because i wired them separately, they do not turn off when the car turns off so I tend to forget about them. I was wondering if there would be a way to tie these into the ignition so when the car shuts off, my lights do too. I appreciate any help. Thanks.
Pete
My car: V70 GLT
Dad's Car: 04 V70
Mom's Car: 02 Saab 9-5 Aero
Old Cars: 84 DL, 89 740 GL, 94 940, 94 850, 2000 S80 2.9
IPB Image
traffic stop counter: 17 times
#2 theunderlord
theunderlord
  • PipPipPipPipPipPip
  • 14,738 posts
Posted 09 May 2005 - 03:58 PM
QUOTE(turboV70 @ May 9 2005, 08:12 AM)
1. why on earth did you wire them that way?
#3 bobcat
bobcat
  • 305 posts
Posted 09 May 2005 - 04:20 PM
you should have wired them into the factory fog light wiring and got the oem switch and relay.
then all you need to do is run an ignition controlled 12v supply into the board up under the dash where the jumper (green cube) goes. this is how i have mine.
im sure some one else will come alone and post the pdf s70 instructions that ive seen floating around.
IPB ImageIPB ImageIPB Image
Volvo 850R Auto, 162K, Bobcat\SW Autos Custom Ecu, 18T, Reverse IC, 13 Row (Mocal Type) Engine Oil Cooler, 39 Row (3x 13 Row's)(Mocal Type) ATF Cooler, 20psi VDO Boost Gauge, Osram 50% Silverstars upfront, ITG Filter, OEM Strutbrace, Aerial Down Switch, 302mm Front Discs, Ferodo DS2500 Pads Front & Rear, Goodridge SS Brake Hoses, New Brake Hard Pipes, ATE Super Blue Brake Fluid, Koni Ajustables, Eibach pro kit, Slaters Link Rods, 4x Nankang NS-2 215/45/17 XL, Clear Side Repeaters, 70 Series Washer Jets, Powerflex Control Arm Bushes.
Fully Synthetic 5w-40 every 5K Miles, and flushed with 10l of Comma Dexron 3 ATF every other oil change.
In Progress: Custom Alu IC with 2.5" Core IC (Same Dimension as Stock one, Just thicker)
To Come: 3" Mandrel Bent down pipe and Cat Back.
#4 theunderlord
theunderlord
  • 14,738 posts
Posted 09 May 2005 - 04:22 PM
QUOTE(bobcat @ May 9 2005, 09:20 AM)
and kevin said.. let there be foglights.
#5 turboV70
turboV70
  • 764 posts
Posted 09 May 2005 - 04:28 PM
Thanks for the help. Yea i know i should have wired it with an oem switch. I put these in a while ago when i knew a lot less about my car. These are only temporary anyway. I'm gettin rid of them when i get V70R bumpers.
Pete
My car: V70 GLT
Dad's Car: 04 V70
IPB Image
#6 theunderlord
theunderlord
  • 14,738 posts
Posted 09 May 2005 - 04:36 PM
QUOTE(turboV70 @ May 9 2005, 09:28 AM)
then what are you gonna do? have the R bumper grill inserts in there with no foglights?
#7 snorrih
snorrih
  • 50 posts
Posted 09 May 2005 - 04:52 PM
So this is the thread ONLY for people with sig. pics of their Volvos with scenic backdrops?
1996 Volvo 850 wagon, B5204 20V NA Automatic transmission
user posted image
#8 theunderlord
theunderlord
  • 14,738 posts
Posted 09 May 2005 - 04:55 PM
QUOTE(snorrih @ May 9 2005, 09:52 AM)
hahahah, good call!
#9 turboV70
turboV70
  • 764 posts
Posted 09 May 2005 - 05:57 PM
no, sorry about that. i shoulda been more specific. The plan is to have R bumpers with the OEM forg lights.
Pete
My car: V70 GLT
Dad's Car: 04 V70
IPB Image
