Evap Code
9 replies to this topic
#1 Guest_DougK_*
Guest_DougK_*
Posted 09 May 2005 - 10:24 PM
Ok, I had a CEL before I tore the car apart but I assumed it was front 02 since my milage had dropped. After I had EGR (I had the vac lines backwards), Knock (I know why) and EVAP. Everything looks hooked up correctly (pretty hard not too) so whats going on? Can that (I assume) check valve(?) be bad?
Thanks Rich!
Doug
#2 MrWinkey
MrWinkey
    Am I drunk? You tell me!
  • 4,759 posts
Posted 09 May 2005 - 11:55 PM
Probably a bad evap valve...not sure of the year being the your not giving OBDII codes
"SMOKE TROUT NOT CRACK"
#3 Guest_DougK_*
Guest_DougK_*
Posted 09 May 2005 - 11:56 PM
1995, sorry forgot to mention that. SO that little valve then eh?
#4 MrWinkey
MrWinkey
  • 4,759 posts
Posted 09 May 2005 - 11:59 PM
Yes Doug...probably the culprit..you don't have a 541 with that? If not replace the valve is my guess wink.gif
#5 Bay13
Bay13
  • 6,378 posts
Posted 10 May 2005 - 12:00 AM
Take the valve off and make sure it holds vacuum in both directions, if it doesn't then it needs replacing. The replacement might require a wiring adapter. I'd also get the filter that goes with it.
#6 Guest_DougK_*
Guest_DougK_*
Posted 10 May 2005 - 12:08 AM
Very cool bud, I'll do that tomorrow at the shop (where my hand vac-pump is).
I think I can rob Carsons if its not stuck in his firewall LOL
#7 Bay13
Bay13
  • 6,378 posts
Posted 10 May 2005 - 12:10 AM
I'm looking for the part numbers for the stuff. Evap, filter, wiring harness.
#8 MrWinkey
MrWinkey
  • 4,759 posts
#9 Volvoson
Volvoson
    Baby On Board Racing
  • 17,264 posts
Posted 10 May 2005 - 12:40 AM
QUOTE(DougK @ May 9 2005, 05:08 PM)
Call me Senior Slice-n-Dice. I got your valve Doug, I'll send it out with the headlight ASAP.
View Postgdizzle, on 21 May 2012 - 03:52 AM, said:
All the clean cars are in the PNW.
#10 prasamin
prasamin
    Bipedal Magnaflux
  • 16,242 posts
Posted 10 May 2005 - 01:27 AM
The Volvo PN for the EVAP kit is 272190 (this is what you need Doug)
The Volvo PN for the inline filter assembly is 1275794
The Bosch PN for the valve is 0 280 142 300
The Volvo PN for the wiring adapter is 1270313 (not included)
Oh, by the way, I have the kit without wiring adapter if you want it for REAL CHEAP....you'd have to find the adapter though....
