Haynes does not metion shims on a front brake job, neither does this site's Bay 13. When I bought my parts last night online, shims were only available for the rears.
The only reason I ask is that when I was price shopping, my local Autozone counter guy said that the shims came with the pads.
I bought Brembo discs (2) and PBR ultimate ceramics (1 set - front). I paid 140 shipped from Auto Parts Place.
Any responses appreciated.
PS. This forum is fantastic!
Newbie Front Brake Job Question
Started by Dougity, May 10 2005 09:54 AM
4 replies to this topic
Posted 10 May 2005 - 09:54 AM
1996 850 turbo, 120K, dk blue, runs great!
Posted 10 May 2005 - 11:17 AM
the fronts dont use shims.
just make sure you use plenty of brake gease on the back of the pads and in the runners on the carriers. also put some inside the piston arouns where the clip goes.
Volvo 850R Auto, 162K, Bobcat\SW Autos Custom Ecu, 18T, Reverse IC, 13 Row (Mocal Type) Engine Oil Cooler, 39 Row (3x 13 Row's)(Mocal Type) ATF Cooler, 20psi VDO Boost Gauge, Osram 50% Silverstars upfront, ITG Filter, OEM Strutbrace, Aerial Down Switch, 302mm Front Discs, Ferodo DS2500 Pads Front & Rear, Goodridge SS Brake Hoses, New Brake Hard Pipes, ATE Super Blue Brake Fluid, Koni Ajustables, Eibach pro kit, Slaters Link Rods, 4x Nankang NS-2 215/45/17 XL, Clear Side Repeaters, 70 Series Washer Jets, Powerflex Control Arm Bushes.
Fully Synthetic 5w-40 every 5K Miles, and flushed with 10l of Comma Dexron 3 ATF every other oil change.
In Progress: Custom Alu IC with 2.5" Core IC (Same Dimension as Stock one, Just thicker)
To Come: 3" Mandrel Bent down pipe and Cat Back.
Posted 10 May 2005 - 11:33 AM
There are several kinds of rear pad shims and it depends on the rear of our car which ones to use. Might want to put year and model in your sig line. No shims on the front of 850 SVC70s.
Posted 10 May 2005 - 11:55 AM
Thanks for the tip, I'm new at the forum and appriciate the guidance. By the way, where is the best place to get the silicone grease?
Thanks again,
Doug
Thanks again,
Doug
Posted 10 May 2005 - 03:08 PM
I really like the Permatex Disc Brake Quiet...You can get it in a spray can and it comes out very liquidy then sets up in about a minute or so....
You can find that at just about any auto parts store
