I am a little confused as to what hardware count I actually need to complete
the replacement of my front struts. A post on the Brickboard stated I needed the following:
P/N 948645 (Strut Mount Bolts/Inside engine compartment) QTY:6
P/N 965194 (Strut Bolts.Inside wheel well) QTY:4
P/N 971099 (Strut nuts/inside wheel well) QTY:4
When I ordered the hardware from FCP Groton, they sent me just 4 large
bolts with 4 matching nuts and 4 small copper nuts. Am I missing some hardware?
Front Strut Replacement
Started by
Guest_Guest_Mr. Detail_*_*
, May 10 2005 01:14 PM
#1 Guest_Guest_Mr. Detail_*_*
Posted 10 May 2005 - 01:14 PM
Posted 10 May 2005 - 01:36 PM
QUOTE(Guest_Mr. Detail_* @ May 10 2005, 08:14 AM)
Depends on what all your doing. I usually replace the big nut ontop of the strut also though if your doing it.
Volvospeed On Google+
Posted 10 May 2005 - 02:24 PM
It would help if you tell us a little more about your car too...
model, year, etc
model, year, etc
Edited by merlin390, 10 May 2005 - 02:25 PM.
