I have a clunk going on in the front passenger side corner. Is this the sway bar bushing or the ball joints or both?
Front End Clunk
Started by stu.f, May 10 2005 10:22 PM
6 replies to this topic
Posted 10 May 2005 - 10:22 PM
It may be a N/A but the paint is shiny ain't it?
93 850glt 5spd
K&N filter
Bilsteins
Posted 10 May 2005 - 10:24 PM
QUOTE(stu.f @ May 10 2005, 04:22 PM)
Could be the upper strut mount. Common problem with the 850. $40 but three hours of labor
Edit: If its a clunk, it probably is the upper strut mount. The ball joints will make a droning or low whine. Sway bar bushing will creak but not clunk.
Edited by R4Life, 10 May 2005 - 10:26 PM.
97 R Gone but not forgotten
Posted 10 May 2005 - 10:27 PM
ok, its definitally a clunk, im not worried about the labor or anything because I plan to install my self
93 850glt 5spd
K&N filter
Bilsteins
Posted 10 May 2005 - 10:28 PM
Another common culprit are swaybar links where. Not too expensive to fix. You can reach in and try to wiggle them to feel if there is play in the joints. Pretty straightforward to fix.
Cheers
Johan
Cheers
Johan
1996 855 2.5 10v NA manual
Few horses and lotsa miles
Posted 10 May 2005 - 10:29 PM
Im still in highschool so I have plenty of time on my hands and a garagebay to work in thanks to the parental units
Edited by stu.f, 10 May 2005 - 10:31 PM.
93 850glt 5spd
K&N filter
Bilsteins
Posted 10 May 2005 - 11:49 PM
Yep probably and end link or upper spring perch
"SMOKE TROUT NOT CRACK"
