I recently purchased a 1996 850 Wagon, with 159,000 on it. It had what the seller called "a skip at idle," which he claimed was probably because of a bad plug or seal. I bought the car cheap, and I'm perfectly willing to put some money into it to get this repaired, but I think the local shop might be trying to oversell me.
The report they gave me states "Eng code: 452 #2 cyl misfire #2 cylinder compression 25PSI." I was told I have two options: junk the car, or replace the engine. Sounds extreme on both counts, but what do I know? This car is a whole different animal from the old 245 I used to drive.
Any thoughts/suggestions?
Thanks.
Can It Be Repaired?
Started by Dom, May 11 2005 12:38 AM
Posted 11 May 2005 - 12:38 AM
Posted 11 May 2005 - 01:37 AM
Either stuff a used engine in it or junk it.
Mark
Mark
Posted 11 May 2005 - 02:25 AM
you could drop the pan, pull the rod cap off. pull the head, push the offending piston out replace and put it all back together
Posted 11 May 2005 - 02:54 AM
are both of the above suggestions based on the compression of that cylinder?...it can't be just based on the misfire....
there has to be some backup to justify replacing the engine....
I mean, get a compression test first, replace some plugs/wires/cap, etc....
