I have 100k+ on my 95 850, and want to go ahead and replace the oil seperator tank when I service the PCV hoses and whatnot.
However, VADIS lists 2 different tanks. Which is the right part number? Does one superceed the other?
Is there any other seals or orings I should replace related to the tank? I already have the 90 degree elbow coupling that goes into the tank. I'm thinking there should be some sort of coupling or oring or something where the tank attaches to the block...
Thanks!
- Slater
Oil Seperator Tank
Started by Slater, May 11 2005 04:58 AM
10 replies to this topic
Posted 11 May 2005 - 04:58 AM
Posted 11 May 2005 - 12:19 PM
bump
help me out on this one - I know a lot of you have replaced your oil seperator...
Posted 11 May 2005 - 12:21 PM
Slater there are two styles based on the engine serial number. I do not remember the cut off number but thats why there is two.
Posted 11 May 2005 - 03:18 PM
Slater, when you find out, I'd like to know which one it is too, and how you figure it out....also would like to know P/N's for the orings and connectors you replace....I really need to do this, but have so much other stuff going on right now!
-Pras-
-Pras-
Posted 11 May 2005 - 03:26 PM
Slater, look at the engine code number that should be on a sticker on the timing belt cover. Here's the info you need:
For engines up to 330413, you need part number 9146756.
For engines 330414 and later, you need part number 1271988.
There aren't any seals related to the box that you need to worry about, but it would be good to make sure all of the lines being routed to and from the PCV to the head and to the air intake hose are free of obstructions. Also, while you have the manifold off, clean up the knock sensors and their connections, but pay attention to their original position and make sure they're put back the way they're found. Also, it would be good to go ahead and replace the vacuum elbow over on the passenger side of the manifold while you have easy access to it.
- Sean
Posted 11 May 2005 - 05:40 PM
QUOTE(White850T5 @ May 11 2005, 11:26 AM)
Awesome - that's exactly what I was looking for!
Thanks!
Posted 12 May 2005 - 12:41 AM
Another case solved by the white rat....I love that mouse...I just can't figure out where I have seen him before...go easy on me now I'm not as young as some of you guys....is it Pinky and the Brain?...Not futurarama?..aahhh..atleast you got him straight on the oil trap issue
"SMOKE TROUT NOT CRACK"
Posted 12 May 2005 - 12:44 AM
it is pinkey and the brain
Posted 12 May 2005 - 02:31 AM
Sean, he just called you a white rat.
QUOTE(MrWinkey @ May 11 2005, 08:47 PM)
Sweet...well I'm not feelin so old now:)...never watched it but have seen it in surfing the channels as all middle aged beer gutted guys do
Your day is coming
if I am still around then I will let ya know OLD MAN!!
