A/c
5 replies to this topic
#1 blackt5r
blackt5r
    NWC Rod Bender
  • 2 posts
Posted 11 May 2005 - 06:38 PM
Had Evaporator replaced last year, since then when I turn on the air I hear a irritating high pitched whistle as I accelerate.
This will occur as I step on the gas pedal, and only occurs when the A/C is on.
I've checked the temp sensors and they check okay.
Any Thoughts?
#2 R4Life
R4Life
  • 933 posts
Posted 11 May 2005 - 07:23 PM
If memory serves right, I had that issue on my car a couple of years ao. It was a faint whine. I believe its a bearing in the A/C fan motor. I had the fan replaced.
Edit : Fan means blower.
Edited by R4Life, 11 May 2005 - 07:27 PM.
97 R Gone but not forgotten
#3 MrWinkey
MrWinkey
    Am I drunk? You tell me!
  • 4,759 posts
Posted 12 May 2005 - 12:31 AM
Doubt the noise is fan related being that it only happens while on accel..and with the A/C on...is it a belt noise possibly....don't know how loud it is and it may be normal, compressor just doing it's job?
"SMOKE TROUT NOT CRACK"
#4 Bay13
Bay13
  • 6,378 posts
Posted 12 May 2005 - 02:29 AM
I'd check the orface tube, if it's semi clogged or the "O" ring going bad you could get a whistle.
#5 blackt5r
blackt5r
    NWC Rod Bender
  • 2 posts
Posted 12 May 2005 - 03:34 PM
QUOTE(Bay13 Admin @ May 12 2005, 02:29 AM)
smile.gif Thanks for the responses!
If the oriface is clogged, can I perform this repair myself? Also, I'm assuming, if the O ring needs replacing, this would require system evacuation and re-pressurization. Correct?
#6 Sherman
Sherman
  • 73 posts
Posted 12 May 2005 - 07:10 PM
Silly question, but where is that? I've been etting a whistle as my AC cycles on and off as well. I recall reading some time ago that there's a valve somewhere, fairly inexpensive that does this as it fails. Maybe I dreamt it...
98 V70XC
