Checking Error Codes
4 replies to this topic
#1 ChrisAunchman
ChrisAunchman
  • 2 posts
Posted 12 May 2005 - 03:17 PM
It seems in the past 2 weeks I have been dragged into working on two simliar volvos. One is a 1998 S70 and the other is a 97 96 850. What I am wondering is the 850 has a no spark condition. I am getting 12 V to the coil, but it it doens't appeear tobe collapsing on the negative side. Which I would normally see this indication on other cars. First off is it being controlled by a "Cam Position Sensor" or a "Crank position Sensor" I dodn't see a magnetic pickup leaving the dizzy so it must be.......I thought I saw a Crank Postion Sensor in the side of the block. If so I am guessing a bad sensor would cause the no spark and would explain why the coil isn't collapsing. I guess I am loking for specs too.....What should the coil voltage be at cranking and running? Is there a ballast resistor somewhere? Also when I measure the voltage accross the wires (+, and I call it Tach wire) I get 0 volts....is this correct? I would think you would have to see 12V. SOrry for the iggnorance not use to Volvo ignitions maybe they do something different. Also where do I read the error codes from?
#2 ChrisAunchman
ChrisAunchman
  • 2 posts
Posted 12 May 2005 - 06:35 PM
QUOTE(ChrisAunchman @ May 12 2005, 11:17 AM)
Anyone any ideas???? Or maybe where I can go to find the specs?
#3 MrWinkey
MrWinkey
    Am I drunk? You tell me!
  • 4,759 posts
Posted 12 May 2005 - 11:45 PM
Try the repairs and maintenance section..sounds like a bad CMP....
"SMOKE TROUT NOT CRACK"
#4 Bay13
Bay13
  • 6,378 posts
Posted 13 May 2005 - 01:35 AM
Hook up a Volvo Scan tool and see what and if any codes are stored.
#5 Guest_Guest_ChrisAunchman_*_*
Posted 13 May 2005 - 03:54 PM
It was the Cam Postion Sensor as I thought................Where is the spec section? Can you pull codes without a scan tool? By working it off the engine light anyway?
