Edited by Plan B, 12 May 2005 - 08:59 PM.
Spark Plugs
Posted 12 May 2005 - 08:56 PM
Posted 12 May 2005 - 08:57 PM
Save your money for higherend fuel.
Volvospeed On Google+
Posted 12 May 2005 - 08:59 PM
Nah behave, Bosch coppers are fab!
Posted 12 May 2005 - 09:03 PM
Alex
I had these in my car and it ran very smooth.
Coppers are good, but they require more voltage to fire and that's why it's not as smooth.
I switched back to copper because of spark blow-out, and I'm not so sure I want to stay with them since the idle isn't as smooth.
EST Intake, 16T @ 15psi, Forged Rods, Speedtuning ECU, iPD HD TCV, iPD Cat-Back, Strut Brace, Bilstein HDs, iPD Grille, Jewel Headlights, 17" Canistos, 215/45/17 Kumho ASX Tires
Posted 12 May 2005 - 09:06 PM
I just called him and that is what they are irudums.
Why did you have plow outs?
I have noticed this also. I had iridiums in there when I got the car and switched to coppers last month. First thing I noticed was the idle was a bit rough. I may also switch back.
Posted 12 May 2005 - 09:09 PM
Posted 12 May 2005 - 09:10 PM
That's what I wanted to know, thanks Chuck.
Posted 12 May 2005 - 09:11 PM
+1
Posted 12 May 2005 - 09:12 PM
When I switched to my 16T the air flow was more and that caused the spark to blow-out before igniting the fuel. I decided to put in coppers gapped to .025 like everyone else.
#16
Posted 12 May 2005 - 09:17 PM
#18
Posted 14 May 2005 - 03:15 AM
The turbocharger is not blowing into the cylinder when the spark plug is firing...unless you have your timing belt a couple of notches out of position on the intake cam sprocket.
What pressure is your turbo putting out?...1 bar?...15 psi. Or less.
What is your compression pressure...somewhere over 150 psi. You can not get compression pressure if your intake valve is open.
Ken
#19
Posted 14 May 2005 - 03:39 AM
Don't tell them that, they actually thought they were blowing out their spark.
#20
Posted 16 May 2005 - 03:24 AM
Ken
Obviously I was mistaken, what is spark blow-out then? and why does a smaller plug gap fix it?
