Upper Torque Arm Bushing
8 replies to this topic
#1 TSWisla
TSWisla
  • 309 posts
Posted 13 May 2005 - 02:10 AM
Is there a trick to installing this thing? I got the old one out and then new one refuses to go in. Any tips? PLEASE HELP!
1998 S70 GLT 140K
#2 shurgen
shurgen
  • 1,136 posts
Posted 13 May 2005 - 02:40 AM
I think it is done with special volvo tool that a dealer should have. OEM bushings aren't installed that often any more, but polyurethane ones that do not need the tool to be put in place.
96 855R 158k miles
#3 TSWisla
TSWisla
  • 309 posts
Posted 13 May 2005 - 03:06 AM
I found a site that explains how to make a homemade tool to push in the oem bushing http://www.matthewsvolvosite.com. One more thing though, there is a smaller bushing that attaches directly to the firewall, should this bushing be replaced also? Thank you!
1998 S70 GLT 140K
#4 Zappo
Zappo
    The One Upper
  • 15,529 posts
Posted 13 May 2005 - 03:29 AM
QUOTE(TSWisla @ May 12 2005, 08:06 PM)
I found a site that explains how to make a homemade tool to push in the oem bushing www.matthewsvolvosite.com.  One more thing though, there is a smaller bushing that attaches directly to the firewall, should this bushing be replaced also?  Thank you!
Are you replacing the stock bushing with another stock one?
#5 Geevs
Geevs
  • 1,808 posts
Posted 13 May 2005 - 04:17 AM
QUOTE(TSWisla @ May 12 2005, 09:06 PM)
I'm the one who wrote that article regarding the home-made $10 tool for replacing the 1-piece stock rubber bushing not the 2-piece poly bushing. If you have any questions about the tool, fire away. Regarding your question about the smaller bushing, never heard about it having to be replaced so I'd leave it alone.
#6 TSWisla
TSWisla
  • 309 posts
yes, I am. Has anyone ever replaced the small bushing?
1998 S70 GLT 140K
#7 Zappo
Zappo
    The One Upper
  • 15,529 posts
Posted 13 May 2005 - 04:27 AM
QUOTE(TSWisla @ May 12 2005, 09:17 PM)
Is it bad? Mine was fine, so I never messed with it.
#8 TSWisla
TSWisla
  • 309 posts
Posted 13 May 2005 - 01:23 PM
Thank you for your reply and great article geeves. As far as the condition of the small bushing, when you move it around, you can see that it is wearing out, though it has not completely broken off like the larger one...
1998 S70 GLT 140K
#9 TSWisla
TSWisla
  • 309 posts
Posted 13 May 2005 - 11:21 PM
I also was not able to squeeze the larger bushing in so that it would be perfectly centered within the bracket, will this be a problem? Thank you.
1998 S70 GLT 140K
